Hi Espressif Systems Developer,
We have started to use ESP32 SoC as well as ESP32 based modules into different product which are running successfully.
Now, I have one question like what is the default state of unused GPIO or IO pads into module itself?
Let's take one example like there is one IO3 which I haven't used into my product then what will be the default state means HIGH or LOW and input or output direction.
So, I just want to get I formation regard that so that I need to configure it from software side if state is tristate or not fixed
Need help to get default state of unused IO pads for ESP32 modules
Regards,
Ritesh Prajapati
Ritesh Prajapati
Re: Need help to get default state of unused IO pads for ESP32 modules
Look at datasheet appendix A you can see that io3 has input mode with weak pull-up and default function is u0rxd
Thanks for Reply.WiFive wrote:Look at datasheet appendix A you can see that io3 has input mode with weak pull-up and default function is u0rxd
I will check and will let you know if any query regarding that.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: No registered users and 74 guests
