errors while connecting esp32 nodemcu to relay
raadiy@yahoo.com
Postby raadiy@yahoo.com » Sun Nov 18, 2018 6:00 am
I have developed an application that interacts with a 8 way relay. The application runs on a ESP32 Nodemcu (Devkitc ) board. I am currently testing the application, and I see the following error. The power supply to the esp32 comes from the PC (via USB), the 3.3 v pin and ground are connected to the Vcc and Ground pins, respectively, of the relay. I have the following pins connected in output mode to the relay (GPIO 15, 2, 4, 5, 18, 19, 21, 22). When the esp32 powered up, I saw the following errors, and I disconnected it. Can someone please help me understand the following errors and their consequence. Many Thanks.
$ make monitor
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
Python requirements from D:/Raajesh/esp32/msys32/home/RAAJESH/esp/esp-idf/requirements.txt are satisfied.
MONITOR
--- idf_monitor on COM5 115200 ---
ts Jun  8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
cmd len -1
ets_main.c 371
cmd len -1
ets_main.c 371
cmd len -1
ets_main.c 371
Re: errors while connecting esp32 nodemcu to relay
Postby ESP_Sprite » Mon Nov 19, 2018 2:29 am
Moved to the hardware subforum.
Users browsing this forum: Google [Bot] and 143 guests
