Running VDD3P3_CPU at 1.8 Volt (ESP32-D2WD)
Kishan
Postby Kishan » Wed Jan 16, 2019 6:48 pm
Is it possible to run VDD3P3_CPU at 1.8 volt while all other supplies are at 2.7 Volt?
If so, is it safe to assume that all IOs will operate at 1.8 volt?
Thank you very much in advace for help.
Kishan
ESP_Lvxinyue
Re: Running VDD3P3_CPU at 1.8 Volt (ESP32-D2WD)
Postby ESP_Lvxinyue » Thu Jan 24, 2019 4:00 am
Kishan
Yes.
Not all IOs, but those in the VDD3P3_CPU power domain. You can refer to the IO_MUX sheet in the ESP32 datasheet: https://www.espressif.com/sites/default ... eet_en.pdf.
Thanks.
Users browsing this forum: No registered users and 58 guests
