ESP32 JTAG JLIN debugger connection problem
asl007
Postby asl007 » Wed Mar 27, 2019 9:48 am
I am trying to use JTAG debugger with the Olimex ESP32-EVB.
I have followed the instructions for connection in this post https://www.olimex.com/forum/index.php?topic=6039.0
and also the espressif tutorial here https://docs.espressif.com/projects/esp ... p32-target
When I run bin/openocd -s share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
I get this output
Open On-Chip Debugger v0.10.0-esp32-20190313 (2019-03-13-09:59)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
Info : Configured 2 cores
esp32 interrupt mask on
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
Warn : Flash driver of esp32.flash does not support free_driver_priv()
Warn : Flash driver of irom does not support free_driver_priv()
Warn : Flash driver of drom does not support free_driver_priv()
Can you help troubleshooting this.
ESP_igrr
Re: ESP32 JTAG JLIN debugger connection problem
Postby ESP_igrr » Wed Mar 27, 2019 2:22 pm
Do you mean "JLink" debugger? Please check your arguments to OpenOCD, currently they say "interface/ftdi/esp32_devkitj_v1.cfg". If you aren't using ESP-WROVER-KIT, you need to use a different interface file. OpenOCD has one for Jlink.
asl007
Postby asl007 » Wed Apr 03, 2019 11:08 am
Yes it is JLINK, my mistake.
SO I have tried to run the command with jlink config file bin/openocd -s share/openocd/scripts -f interface/jlink.cfg -f board/esp-wroom-32.cfg
But I get some errors:
Info : J-Link V9 compiled Oct 25 2018 11:46:07
Info : Hardware version: 9.40
Info : VTarget = 3.354 V
Info : Reduced speed from 20000 kHz to 15000 kHz (maximum).
Info : clock speed 20000 kHz
Have been researching about it but I am not able to get it solved
Users browsing this forum: No registered users and 88 guests
