I'm new to this esp environment. I'm trying compile hello_world in my windows 7 pc but I'm getting a error that I couldn't solved even after searching for solutions online. I will be thankful if anybody could help me to solve this issue. I attached the error which I'm getting as a image file. Thanks in advance.
Windows error finding requirements.txt
- esp_error.png (169.22 KiB) Viewed 2360 times
Re: Windows error finding requirements.txt
Hi Dhananjay,
The requirements.txt file is in a different directory to your project. If you copy and paste the suggested command from the error (with the full path to requirements.txt) then it should work.
Angus
Angus
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 152 guests
