NVS non deterministic behavior
mairswartz
Postby mairswartz » Mon Apr 15, 2019 10:53 am
I'm getting some strange behavior with NVS.
Here is the source code. Note the commented line of code where I have a delay
If that line is commented the output is NVS: Value not set yet
However un-commented the output is NVS: Value is 1
To flash the chip I am using
make -j8 erase_flash flash monitor
Which should erase the flash each time.
Can anyone explain to me why the code behaves differently with a delay. It seems like its almost running asynchronously without blocking. Is this perhaps a bug?
#include <stdio.h>
#include <string.h>
#include "esp_log.h"
#include "nvs.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "esp_system.h"
#define TAG "NVS"
void app_main()
  ESP_LOGW(TAG, "Started!!!");
  nvs_flash_init();
  nvs_handle handle;
  nvs_open("store", NVS_READWRITE, &handle);
  int32_t val = 0;
  esp_err_t err = nvs_get_i32(handle,"val1", &val);
  // vTaskDelay(1000 / portTICK_PERIOD_MS);
  switch (err)
    case ESP_ERR_NVS_NOT_FOUND:
      ESP_LOGE(TAG, "Value not set yet");
      break;
    case ESP_OK:
      ESP_LOGI(TAG,"Value is %d", val);
      break;
    default:
      ESP_LOGE(TAG, "Error (%s) opening NVS handle!\n", esp_err_to_name(err));
      break;
  printf("completed reading\n");
  val++;
  nvs_set_i32(handle,"val1",val);
  nvs_commit(handle);
  nvs_close(handle);
check out my course https://learnesp32.com
Users browsing this forum: No registered users and 130 guests
