Need help to overrite one of file from component into ESP32
Ritesh
Contact:
Re: Need help to overrite one of file from component into ESP32
Postby Ritesh » Mon Apr 22, 2019 7:07 am
xiaoxufeng wrote:
Mon Apr 22, 2019 5:23 am
Each component is treated as an individual part when maintaining the component. Back compatible are only ensured at the component level.
I'm afraid that overriding a single file may make you more risky when you update the IDF.
Ritesh wrote:
Sat Apr 20, 2019 4:03 am
ESP_Sprite wrote:
Sat Apr 20, 2019 12:46 am
Sorry, we don't really have a way to override just one file... overrides happen on component levels only.
Thanks for your quick response regarding same.
Do you have any suggestion or solution to override single file because we need to include that support into existing SDK. Also, It is little bit risky to override whole component in which there are almost core libraries and other source files are present.
Just check from your end if possible otherwise I need to find any alternative solution for same.
As ESP32 SDK Developer has mentioned that there is no any hooks to override single file into component and also that is risky in case of that particular component update.
So, I will check it again from my side regarding same and get back to you if I will find any proper solution for same.
Regards,
Ritesh Prajapati
Users browsing this forum: Baidu [Spider] and 214 guests
