Important hint:
You have to make sure that there is always only one process/task that is accessing LittleFs at the same time.
Otherwise you will get error-codes, malfunction or even a complete crash.
SPIFFS and FFat are more robust in that cases.
Wear levelling FATFS performance really slow even for reading?
Re: Wear levelling FATFS performance really slow even for reading?
Yes - personally I use ESP-IDF's VFS layer so I can use POSIX style file calls, and on each of those wrappers I've added a mutex check.
Jason
Jason
Users browsing this forum: No registered users and 195 guests
