WIFI to WPA2:
kkbbesp
WIFI to WPA2:
Postby kkbbesp » Tue Apr 30, 2019 7:32 pm
Hello All,
I am just getting started with ESP32, and wish to join a WPA2 AP.
I tried out this example:
https://github.com/espressif/esp-idf/bl ... ise_main.c
and keep getting this error:
 src/test.c: In function 'event_handler':
src/test.c:83:23: error: 'WIFI_EVENT' undeclared (first use in this function)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
src/test.c:83:23: note: each undeclared identifier is reported only once for each function it appears in
src/test.c:83:49: error: 'WIFI_EVENT_STA_START' undeclared (first use in this function)
src/test.c:85:56: error: 'WIFI_EVENT_STA_DISCONNECTED' undeclared (first use in this function)
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
src/test.c:88:30: error: 'IP_EVENT' undeclared (first use in this function)
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
src/test.c:88:54: error: 'IP_EVENT_STA_GOT_IP' undeclared (first use in this function)
I did include esp_wifi_types.h.
  • Platform : Linux
    IDE : PlatformIO
    Device: ESP32 Pico Kit V4.1
    IDF Version: 1.8.0
i did a system wide search for WIFI_EVENT_STA_DISCONNECTED and could not find anything that matches:
"#define WIFI_EVENT_STA_DISCONNECTED ..." (
grep -Inr "#define.*WIFI_EVENT_STA_DISCONNECTED" ./*
How do I fix this? Thanks in advance.
Krish.
WiFive
Re: WIFI to WPA2:
Postby WiFive » Wed May 01, 2019 10:59 am
You have to use a version that matches platformio
https://github.com/espressif/esp-idf/tr ... enterprise
kkbbesp
Re: WIFI to WPA2:
Postby kkbbesp » Wed May 01, 2019 3:01 pm
Thank you.
I seems like my platformio framework-espidf version is 3.30200.190418 (3.2.0).
And when i look even at the v2.0 branch of the example on github, the referenced variables are the same ( SYSTEM_EVENT_STA_START , SYSTEM_EVENT_STA_GOT_IP , SYSTEM_EVENT_STA_DISCONNECTED etc).
After further digging I see the framework I download from github has a slightly different components/esp32/include/esp_wifi_types.h file from that installed in platformio's 3.3 version (.platformio/packages/framework-espidf/components/esp32/include/esp_wifi_types.h)
Maybe this is a question for platformio, but if anyone know of a way to fix this please let me know.
Users browsing this forum: Baidu [Spider] and 282 guests
