Generating libwpa_supplicant.a.sections_info
Generating libxtensa-debug-module.a.sections_info
Generating esp32.project.ld
File "/home/carl/桌面/esp-idf/tools/ldgen/ldgen.py", line 113, in <module>
main()
File "/home/carl/桌面/esp-idf/tools/ldgen/ldgen.py", line 88, in main
sections_infos.add_sections_info(sections_info_file_obj)
File "/home/carl/桌面/esp-idf/tools/ldgen/generation.py", line 606, in add_sections_info
raise ParseException("File " + sections_info_file.name + " is not a valid sections info file. " + p.message)
pyparsing.ParseException: File /home/carl/桌面/esp-idf/app/build/app_trace/libapp_trace.a.sections_info is not a valid sections info file. (at char 0), (line:1, col:1)
/home/carl/桌面/esp-idf/components/esp32/Makefile.projbuild:50: recipe for target '/home/carl/桌面/esp-idf/app/build/esp32/esp32.project.ld' failed
make: *** [/home/carl/桌面/esp-idf/app/build/esp32/esp32.project.ld] Error 1
I use win10 and ubuntu18.04 to compile ESP32 project and all meet this probliem, but when compile other ESP8266 project(use lx106 toolchain) it is no error occurr
i need some help , the PC environment is new, i use old PC to compile is OK..... why....
Some problems encountered in Compile
Re: Some problems encountered in Compile
Can you see if renaming the folder with Chinese characters in it to something that has normal ASCII characters in it works? If not, can you post /home/carl/桌面/esp-idf/app/build/app_trace/libapp_trace.a.sections_info here?
Users browsing this forum: Bing [Bot], jgrossholtz and 188 guests
