Just throwing this out there, in case someone else have had the same issues and found a solution...
After successfully initializing a 32GB SD Card using the MMC driver and mounting it at/sdcard, I can access files directly in the root, such as /sdcard/index.htm. However, accessing files in a sub directory, such as /sdcard/web_root/index.htm fails. Neither fopen() nor stat() is able to access the file.
I have enabled long file names in menuconfig, still using default char set.
Is there another option that has to be enabled to support directories?
[Solved] FatFS/MMC and paths
Re: FatFS/MMC and paths
No idea what went wrong yesterday, its all working now.
Users browsing this forum: Baidu [Spider] and 144 guests
