GPIO Interrupts (Advice please)
papafritus
Postby papafritus » Sun May 19, 2019 5:39 am
Hi all,
I'm working with GPIO Interrupts (its my first time) and I really need advice on my code.
The thing is simple: To detect a push button with an interrupt.
The code set the interrupt and when detect the button pressed, disable the interrupt for a time.
Its ok? Is there a better way to do it? Is there a good place to read about it?
Thanks in advance!
#include <stdio.h>
#include "esp_timer.h"
#include "driver/gpio.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#define BLINK_LED      32  //Just a led blinking
#define BUTTON_LED_1   25  //This Led light for a second when button is pressed
#define PUSH_BUTTON_1  27
#define ESP_INTR_FLAG_DEFAULT 0
static int b_presionado_1 = 0;  //a flag: 1 = button pressed, 0 = button released
static int b_letInt_1 = 0;      //a flag: 0 = dont let the interrupt happen, 1 = let it
void triggered_1_isr(void* instance)
	b_presionado_1 = 1;
	b_letInt_1 = 0;
	gpio_intr_disable(BUTTON_LED_1);
void app_main(void)
	unsigned long tiempo;
	unsigned long temporizador_1;
	unsigned long temporizador_2;
	int estadoLed;
	gpio_pad_select_gpio(BLINK_LED);
	gpio_set_direction(BLINK_LED, GPIO_MODE_OUTPUT);
	gpio_pad_select_gpio(BUTTON_LED_1);
	gpio_set_direction(BUTTON_LED_1, GPIO_MODE_OUTPUT);
	gpio_pad_select_gpio(PUSH_BUTTON_1);
	gpio_set_direction(PUSH_BUTTON_1, GPIO_MODE_INPUT);
	gpio_pullup_en(PUSH_BUTTON_1);
	gpio_pulldown_dis(PUSH_BUTTON_1);
	gpio_set_intr_type(PUSH_BUTTON_1, GPIO_INTR_NEGEDGE);
	gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
	gpio_isr_handler_add(PUSH_BUTTON_1, triggered_1_isr, (void*) PUSH_BUTTON_1);
	gpio_intr_enable(PUSH_BUTTON_1);
	b_letInt_1 = 1;
	tiempo = esp_timer_get_time();
	temporizador_1 = esp_timer_get_time();
	gpio_set_level(BLINK_LED, 1);
	estadoLed = 0;
    while (true)
    	//-------------------------- Keep a led blinking every 0,5s ---------------------------
		if(esp_timer_get_time() - tiempo > 500000 && estadoLed == 0)
			gpio_set_level(BLINK_LED, 0);
			estadoLed = 1;
		if(esp_timer_get_time() - tiempo > 500000 && estadoLed == 1)
			estadoLed = 0;
		//If button is press light a led and start a timer
		if(b_presionado_1)
			b_presionado_1 = 0;
			gpio_set_level(BUTTON_LED_1, 0);
		//Check the timer for the button led. If greater than 1s, then lights off and let new interrupts
		if(!b_letInt_1)
			if(esp_timer_get_time() - temporizador_1 > 1000000)
				gpio_set_level(BUTTON_LED_1, 1);
				b_letInt_1 = 1;
WiFive
Re: GPIO Interrupts (Advice please)
Postby WiFive » Mon May 20, 2019 9:28 am
You shouldn't have blocking infinite loops in rtos tasks. Either insert vtaskdelay or use a timer callback.
Users browsing this forum: HitecSmartHome and 262 guests
