Hi ESP32 devs...
Some background:
I am trying to port an application form TI-CC3200 to ESP32. Ass part of the process I had to convert a number of modules to accommodate the ESPO-IDF FreeRTOS changes as some ESP32 peripherals
After lots of effort I have it compiling but now the linker is failing with the following error message:
c:/msys32/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find crt1-sim.o: No such file or directory
c:/msys32/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find _vectors.o: No such file or directory
c:/msys32/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lsim
c:/msys32/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lhandlers-sim
c:/msys32/opt/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/5.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: cannot find -lhal
I have also included the makefile below.
All help and pointers appreciated.
Andre
PS: tried to attach the build file "build.log" but get error about an invalid extension.
------------------------------------------------ Makefile -------------------------------------------------------
# This is a project Makefile. It is assumed the directory this Makefile resides in is a
# project subdirectory.
PROJECT_NAME := application
SRCDIRS := /c/Dropbox/devs/ws/z-support/common \
/c/Dropbox/devs/ws/z-support/esp32t \
/c/Dropbox/devs/ws/esp32/esp-1 \
/c/Dropbox/devs/ws/z-support/FreeRTOS/FRextras
CFLAGS := -I /c/Dropbox/devs/ws/z-support/common \
-I /c/Dropbox/devs/ws/z-support/esp32t \
-I /c/Dropbox/devs/ws/z-support/FreeRTOS/FRextras \
-I /c/Dropbox/devs/ws/z-sdk/esp-idf/components/freertos/include/freertos
LDFLAGS := -L /c/Dropbox/devs/ws/z-support/common \
-L /c/Dropbox/devs/ws/z-support/esp32t
include $(IDF_PATH)/make/project.mk
LD cannot find crt1-sim.o _vectors.o -lsim -lhandlers-sim -lhal
Re: LD cannot find crt1-sim.o _vectors.o -lsim -lhandlers-sim -lhal
By setting LDFLAGS, you overrule the esp-idf defaults. Can you try setting EXTRA_LDFLAGS instead, see if that gives the result you need?
Thanks for the help, much appreciated.
It fixed 90% of the problem, only had to add a 3rd EXTRA_LDFLAGS entry to get it to find the main appl, after that it linked..
Andre
Andre
Hi Andre,
I'm currently trying to do exactly the same task.
I realise it's over a year since you did the change, but could you please post the content of your LDFLAGS?
Regards,
Geoff
Regards,
Geoff
As said before: don't mess around with LDFLAGS (unless you're 101% sure of what you do), modify EXTRA_LDFLAGS instead.
Users browsing this forum: Majestic-12 [Bot] and 125 guests
