SPI timing violation using hardware chip-select
- luca.gamma
Configuring the SPI master peripheral (HSPI) I require at least half bit-cycle after transmission before the chip-select becomes inactive. The SPI device interface configuration structure has a member called 'cs_ena_posttrans' which should be set to the number of bit-cycle to wait. Actually setting this member to 0 the CS rise just after the last transmission clock but setting to 1 the timing doesn't change. To add 1 bit-cycle I had to set the value to 2 or 3 to wait for 2 bit-cycles and so on. Is this a bug or is it in some way the desired behaviour?
Re: SPI timing violation using hardware chip-select
Seems like bug as TRM doesn't say number of cycles minus one but that is what driver uses
Huh, may be my bad. I'll look into it.
Users browsing this forum: No registered users and 127 guests
