HTTP Requests - Example
Paladin
Postby Paladin » Thu Apr 06, 2017 8:22 pm
I'm working from the HTTP_request_example, and it's not working exactly as I expected it to. Specifically, it's not printing the the HTTP response message to standard IO.
I'm testing via http://httpbin.org/get, and using both:
$ curl http://httpbin.org/get
and Postman to send:
GET /get HTTP/1.1
Host: httpbin.org
User-Agent: esp-idf/1.0 esp32
and in both cases I get the expected response:
  "args": {},
  "headers": {
    "Accept": "*/*",
    "Connection": "close",
    "Host": "httpbin.org",
    "User-Agent": "curl/7.51.0"
  "origin": "73.0.241.158",
  "url": "http://httpbin.org/get"
However, when I configure the ESP-IDF HTTP Request example to match:
/* Constants that aren't configurable in menuconfig */
#define WEB_SERVER "httpbin.org"
#define WEB_PORT 80
#define WEB_URL "/get"
I also added an innocuous print statement to confirm the HTTP request that I think I'm sending is actually the one I'm sending with:
printf("%s", REQUEST);
...which is inserted right before the request is written to the socket...
I get the following (abbreviated) output:
 (2210) example: Connected to AP
I (2380) example: DNS lookup succeeded. IP=184.72.248.171
I (2380) example: ... allocated socket
I (2430) example: ... connected
GET /get HTTP/1.1
Host: httpbin.org
I (2430) example: ... socket send success
I (11180) wifi: pm start, type:0
At this point it just waits. But i'm expecting it to print the response message based on this snippet:
/* Read HTTP response */
        do {
            bzero(recv_buf, sizeof(recv_buf));
            r = read(s, recv_buf, sizeof(recv_buf)-1);
            for(int i = 0; i < r; i++) {
                putchar(recv_buf[i]);
        } while(r > 0);
So...where could I have gone wrong on this?
MalteJ
Re: HTTP Requests - Example
Postby MalteJ » Thu Apr 06, 2017 9:19 pm
The example is not checking for the end of the HTTP response correctly.
A quick fix would be to replace HTTP/1.1 by HTTP/1.0 in the HTTP request.
Like this (line 49)
static const char *REQUEST = "GET " WEB_URL " HTTP/1.0\n"
Best,
Malte
Paladin
Postby Paladin » Thu Apr 06, 2017 11:56 pm
I've tried that, but it did not fix it.
MalteJ
Postby MalteJ » Fri Apr 07, 2017 9:54 am
also the new lines in the request must be \r\n instead of \n
like this:
static const char *REQUEST = "GET " WEB_URL " HTTP/1.0\r\n"
    "Host: "WEB_SERVER"\r\n"
    "User-Agent: esp-idf/1.0 esp32\r\n"
    "\r\n";
If this doesn't help, can you paste your whole C file in a pastebin or gist? https://gist.github.com/
Best,
Malte
Paladin
Postby Paladin » Fri Apr 07, 2017 11:31 am
Thanks. Adding the \r seems to have fixed it.
MalteJ
Postby MalteJ » Sat Apr 08, 2017 12:15 am
Great! :)
I have created a pull request to fix this issue:
https://github.com/espressif/esp-idf/pull/500
Best,
Malte
saraedward
Postby saraedward » Sat Apr 08, 2017 6:08 am
GET /get HTTP/1.1
Host: httpbin.org
try to optimize this code
Users browsing this forum: No registered users and 202 guests
