How to format sd card?
I'm considering formatting the sd card (surface-mount IC) with a command or function, as a maintenance option. I know that you can format the card if it fails to mount but I'm talking about a healthy card that may have developed some file system corruptions and a quick format is necessary for stability. I couldn't find examples of this. Can someone point me in the correct direction? Thanks.
Re: How to format sd card?
esp_err_t formatSD()
FRESULT res = FR_OK;
esp_err_t err = ESP_OK;
const size_t workbuf_size = 4096;
void *workbuf = NULL;
ESP_LOGW(TAG, "partitioning card");
workbuf = ff_memalloc(workbuf_size);
if (workbuf == NULL)
return ESP_ERR_NO_MEM;
DWORD plist[] = {100, 0, 0, 0};
res = f_fdisk(pdrv, plist, workbuf);
if (res != FR_OK)
err = ESP_FAIL;
ESP_LOGE(TAG, "f_fdisk failed (%d)", res);
else
size_t alloc_unit_size = 512;
ESP_LOGW(TAG, "formatting card, allocation unit size=%d", alloc_unit_size);
res = f_mkfs("", FM_FAT, alloc_unit_size, workbuf, workbuf_size);
if (res != FR_OK)
err = ESP_FAIL;
ESP_LOGE(TAG, "f_mkfs failed (%d)", res);
ESP_LOGW(TAG, "partitioning card finished");
free(workbuf);
return err;
Thanks. Which header file should I include for ff_memalloc()? I can't find it in ESP-IDF doc so I assume it may be part of POSIX or RTOS call?
I dont know exactly, but i borrowed this code from espressif. Its one of header files in that file:
https://github.com/espressif/esp-idf/bl ... .c#L15-L21
This might be a dumb question but how can you find the pdrv of a sd card plugged into the board?chegewara wrote: ↑Wed Feb 10, 2021 6:12 pmCode: Select all
esp_err_t formatSD() { FRESULT res = FR_OK; esp_err_t err = ESP_OK; const size_t workbuf_size = 4096; void *workbuf = NULL; ESP_LOGW(TAG, "partitioning card"); workbuf = ff_memalloc(workbuf_size); if (workbuf == NULL) { return ESP_ERR_NO_MEM; } DWORD plist[] = {100, 0, 0, 0}; res = f_fdisk(pdrv, plist, workbuf); if (res != FR_OK) { err = ESP_FAIL; ESP_LOGE(TAG, "f_fdisk failed (%d)", res); } else { size_t alloc_unit_size = 512; ESP_LOGW(TAG, "formatting card, allocation unit size=%d", alloc_unit_size); res = f_mkfs("", FM_FAT, alloc_unit_size, workbuf, workbuf_size); if (res != FR_OK) { err = ESP_FAIL; ESP_LOGE(TAG, "f_mkfs failed (%d)", res); } } ESP_LOGW(TAG, "partitioning card finished"); free(workbuf); return err; }
i dont remember, you would have to study esp-idf code, but what i remember is that first pdrv is always 0, so you can assume its 0 if you have 1 sd card.
I tried to combine this snippet with sdspi example in esp_idf and I got a panic abort during execution. Do you have any idea why it is?
/* Sys Library */ #include <sys/unistd.h> #include <sys/stat.h> /* Standard Library */ #include <stdio.h> #include <inttypes.h> #include <string.h> /* Defined Library in ESP-IDF */ #include "ff.h" #include "esp_vfs_fat.h" #include "sdmmc_cmd.h" #include "vfs_fat_internal.h" #include "sdkconfig.h" #include "esp_chip_info.h" #include "esp_flash.h" #include "esp_log.h" #include "diskio_impl.h" static const char *TAG = "sdFormat"; #define MOUNT_POINT "/sdcard" // Pin assignments can be set in menuconfig, see "SD SPI Example Configuration" menu. // You can also change the pin assignments here by changing the following 4 lines. #define PIN_NUM_MISO 0 #define PIN_NUM_MOSI 4 #define PIN_NUM_CLK 3 #define PIN_NUM_CS 8 esp_err_t formatSD() { FRESULT res = FR_OK; esp_err_t err = ESP_OK; const size_t workbuf_size = 4096; void* workbuf = NULL; ESP_LOGI(TAG, "partitioning card"); workbuf = ff_memalloc(workbuf_size); ESP_LOGI(TAG, "memalloc completed"); if (workbuf == NULL) { ESP_LOGI(TAG, "work buffer null"); return ESP_ERR_NO_MEM; } // PARTITION VolToPart[FF_VOLUMES] = { // {0, 1}, // {0, 2} // }; DWORD plist[] = {100 , 0, 0}; ESP_LOGI(TAG, "Ready to fdisk"); res = f_fdisk(0, plist, workbuf); ESP_LOGI(TAG, "fdisk completed"); if (res != FR_OK) { err = ESP_FAIL; ESP_LOGE(TAG, "f_fdisk failed (%d)", res); } else { ESP_LOGI(TAG, "Ready to mkfs"); res = f_mkfs("0:", 0, workbuf, workbuf_size); if (res != FR_OK) { err = ESP_FAIL; ESP_LOGE(TAG, "f_mkfs failed (%d)", res); } //res = f_mkfs("1:", 0, workbuf, workbuf_size); if (res != FR_OK) { err = ESP_FAIL; ESP_LOGE(TAG, "f_mkfs failed (%d)", res); } } ESP_LOGI(TAG, "partitioning card finished"); free(workbuf); FATFS fs; f_mount(&fs, "0:", 0); f_mount(&fs, "1:", 0); ESP_LOGI(TAG, "mounting drive finished"); return err; } void app_main(void) { esp_err_t ret; // Options for mounting the filesystem. // If format_if_mount_failed is set to true, SD card will be partitioned and // formatted in case when mounting fails. esp_vfs_fat_sdmmc_mount_config_t mount_config = { #ifdef CONFIG_EXAMPLE_FORMAT_IF_MOUNT_FAILED .format_if_mount_failed = true, #else .format_if_mount_failed = false, #endif // EXAMPLE_FORMAT_IF_MOUNT_FAILED .max_files = 5, .allocation_unit_size = 16 * 1024 }; sdmmc_card_t *card; const char mount_point[] = MOUNT_POINT; ESP_LOGI(TAG, "Initializing SD card"); // Use settings defined above to initialize SD card and mount FAT filesystem. // Note: esp_vfs_fat_sdmmc/sdspi_mount is all-in-one convenience functions. // Please check its source code and implement error recovery when developing // production applications. ESP_LOGI(TAG, "Using SPI peripheral"); sdmmc_host_t host = SDSPI_HOST_DEFAULT(); host.max_freq_khz = 10000; spi_bus_config_t bus_cfg = { .mosi_io_num = PIN_NUM_MOSI, .miso_io_num = PIN_NUM_MISO, .sclk_io_num = PIN_NUM_CLK, .quadwp_io_num = -1, .quadhd_io_num = -1, .max_transfer_sz = 4000, }; ret = spi_bus_initialize(host.slot, &bus_cfg, SDSPI_DEFAULT_DMA); if (ret != ESP_OK) { ESP_LOGE(TAG, "Failed to initialize bus."); return; } // This initializes the slot without card detect (CD) and write protect (WP) signals. // Modify slot_config.gpio_cd and slot_config.gpio_wp if your board has these signals. sdspi_device_config_t slot_config = SDSPI_DEVICE_CONFIG_DEFAULT(); slot_config.gpio_cs = PIN_NUM_CS; slot_config.host_id = host.slot; ESP_LOGI(TAG, "Mounting filesystem"); ret = esp_vfs_fat_sdspi_mount(mount_point, &host, &slot_config, &mount_config, &card); // ret = initialize_card(mount_point, &host, &slot_config, &card); if (ret != ESP_OK) { if (ret == ESP_FAIL) { ESP_LOGE(TAG, "Failed to mount filesystem. " "If you want the card to be formatted, set the CONFIG_EXAMPLE_FORMAT_IF_MOUNT_FAILED menuconfig option."); } else { ESP_LOGE(TAG, "Failed to initialize the card (%s). " "Make sure SD card lines have pull-up resistors in place.", esp_err_to_name(ret)); } return; } ESP_LOGI(TAG, "Filesystem mounted"); formatSD(); // All done, unmount partition and disable SPI peripheral // esp_vfs_fat_sdcard_unmount(mount_point, card); // ESP_LOGI(TAG, "Card unmounted"); //deinitialize the bus after all devices are removed spi_bus_free(host.slot); }
Users browsing this forum: tomy983 and 254 guests
