Hi, ive been trying to implement the Dshot1200 protocol
(16-Bit Frames at 1200kbit/s,
≈625ns high + ≈208ns low -> 1,
≈313ns high + ≈620ns low -> 0)
using the MCPWM driver. Im wondering what frequency I can achieve.
Setting the timer configs .resolution_hz higher than 8MHz doesnt result in a faster tickrate, while only setting it higher than 80MHz leads to an error (clock divider not between 256 and 1 anymore).
The lowest stable tick duration (measured using a Logic Analyzer) was around 125ns (8MHz), sometimes 42,5ns but very unstable.
Source:
#include "freertos/task.h"
#include "esp_log.h"
#include "driver/mcpwm_prelude.h"
static const char *TAG = "example";
#define SERVO_PULSE_GPIO 17
#define SERVO_TIMEBASE_RESOLUTION_HZ 8000000
#define SERVO_TIMEBASE_PERIOD 3
void app_main(void)
ESP_LOGI(TAG, "Create timer and operator");
mcpwm_timer_handle_t timer = NULL;
mcpwm_timer_config_t timer_config = {
.group_id = 0,
.clk_src = MCPWM_TIMER_CLK_SRC_PLL160M,
.resolution_hz = SERVO_TIMEBASE_RESOLUTION_HZ,
.period_ticks = SERVO_TIMEBASE_PERIOD,
.count_mode = MCPWM_TIMER_COUNT_MODE_UP,
ESP_ERROR_CHECK(mcpwm_new_timer(&timer_config, &timer));
mcpwm_oper_handle_t oper = NULL;
mcpwm_operator_config_t operator_config = {
.group_id = 0,
ESP_ERROR_CHECK(mcpwm_new_operator(&operator_config, &oper));
ESP_LOGI(TAG, "Connect timer and operator");
ESP_ERROR_CHECK(mcpwm_operator_connect_timer(oper, timer));
ESP_LOGI(TAG, "Create comparator and generator from the operator");
mcpwm_cmpr_handle_t comparator = NULL;
mcpwm_comparator_config_t comparator_config = {
.flags.update_cmp_on_tep = true,
ESP_ERROR_CHECK(mcpwm_new_comparator(oper, &comparator_config, &comparator));
mcpwm_gen_handle_t generator = NULL;
mcpwm_generator_config_t generator_config = {
.gen_gpio_num = SERVO_PULSE_GPIO,
ESP_ERROR_CHECK(mcpwm_new_generator(oper, &generator_config, &generator));
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator, 1));
ESP_LOGI(TAG, "Set generator action on timer and compare event");
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_timer_event(generator,
MCPWM_GEN_TIMER_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, MCPWM_TIMER_EVENT_EMPTY, MCPWM_GEN_ACTION_HIGH)));
ESP_ERROR_CHECK(mcpwm_generator_set_action_on_compare_event(generator,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator, MCPWM_GEN_ACTION_LOW)));
ESP_LOGI(TAG, "Enable and start timer");
ESP_ERROR_CHECK(mcpwm_timer_enable(timer));
ESP_ERROR_CHECK(mcpwm_timer_start_stop(timer, MCPWM_TIMER_START_NO_STOP));
MCPWM maximum timer frequency
Re: MCPWM maximum timer frequency
Why not use the RMT peripheral for that? It's way more suitable for that task.
Okay, wrong peripheral, gotcha. But still, shouldnt the mcpwm timer frequency be higher than what I achieved?
Thanks for the help.
Possibly, sorry, I don't know MCPWM that well.
We have the example for DShot protocol https://github.com/espressif/esp-idf/tr ... /dshot_esc
Users browsing this forum: Baoshi and 206 guests
