Need help for scan_evt timeout error
Ritesh
Contact:
Postby Ritesh » Fri Aug 25, 2023 3:32 am
Hello Team,
We are using Wi-Fi and BLE together into one of our IoT based application in which below is overall scenarios for application perspective.
1. Board Start with ESP32 Device work as STA Mode
2. Enable BLE and scan parameter using esp_ble_gap_set_scan_params
3. Also tried to scan list of Access Points and connects with particular SSID
4. Connect with HTTP Client and send some data
5. Repeat above cycles every 15 Minutes of duration
But we have seen that sometimes we are seeing below prints continuously into random way. I am not sure that from where it is coming and what is the impact of it.
"24-08-2023 AM 1:26:41",scan_evt timeout
"24-08-2023 AM 1:26:42",scan_evt timeout
Let me know if anyone has any idea regaring this.
Regards,
Ritesh Prajapati
Ritesh
Contact:
Re: Need help for scan_evt timeout error
Postby Ritesh » Fri Aug 25, 2023 5:22 pm
Hello ESP_Sprite and Espressif Team,
Hope you are doing well and everything is going well.
Would you please check and let me know in which scenarios we will get this kind of prints? Also will it create any impact due to this kind of prints?
Regards,
Ritesh Prajapati
Ritesh
Contact:
Postby Ritesh » Mon Aug 28, 2023 3:03 am
Hello Team,
Anyone has any updates regarding this issue or have faced this type of issues earlier? Because we have faced this issue few times where we are developing one Bluetooth and WiFi based product.
Let me know if need anything else from my end.
Regards,
Ritesh Prajapati
florian-ats
Postby florian-ats » Sat Nov 04, 2023 12:57 am
Which version of ESP-IDF are you using?
Ritesh
Contact:
Postby Ritesh » Sun Nov 26, 2023 4:40 pm
We are using ESP32 IDF 5.0 Release but it seems like issue has been resolved from ESP32 Stack level and it has been released by Espressif team soon with details as well.
You can get more information from below thread which is ongoing.
https://github.com/espressif/esp-idf/issues/9384
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 216 guests
