ESP IDF - CMakeList Configuration for Multiple Projects
BlackSmith40
Postby BlackSmith40 » Mon Nov 06, 2023 4:40 pm
I've 3 projects and I want to manage them in a single project environment. I've a list of components under folder components and I've 3 lists in my top level CMakeLists.txt file for components to be built for each project. It's something like this
list(APPEND COMPONENTS_PROJECT_A
    comp1
    comp2
    comp3
list(APPEND COMPONENTS_PROJECT_B
    comp2
    comp3
    comp4
list(APPEND COMPONENTS_PROJECT_C
    comp1
    comp3
    comp5
I noticed that CONFIG definitions are available after project() call. But I need this before because I need to update my component list to be built and pass it to CMake build system by calling project(). Therefore, I'm parsing sdkconfig file at top of my CMakeLists.txt file to determine project type which is set via menuconfig.
..... SDKCONFIG PARSING ....
if(PROJECT_TYPE STREQUAL "PROJECT_A")
    set(REQUIRED_COMPONENTS ${COMPONENTS_PROJECT_A})
elseif(PROJECT_TYPE STREQUAL "PROJECT_B")
    set(REQUIRED_COMPONENTS ${COMPONENTS_PROJECT_B})
elseif(PROJECT_TYPE STREQUAL "PROJECT_C")
    set(REQUIRED_COMPONENTS ${COMPONENTS_PROJECT_C})
else()
    message(FATAL_ERROR)
endif()
#Only build required components rather than everything in components directories.
set(COMPONENTS ${REQUIRED_COMPONENTS})
So far so good it works but my problem is I can't pass PROJECT_TYPE info to my components CMakeLists.txt file. I know that CONFIG_PROJECT_TYPE is available to components but When I called project() I observed following:
-- Calling project(XXXXXXX)
-- ccache will be used for faster recompilation
-- Component-level PROJECT_TYPE:
-- Component-level PROJECT_TYPE: PROJECT_A
It's called twice and only in the second run, PROJECT_TYPE variable is available. This causes compile error because I conditionally change required component list considering selected project type.
How can I fix this problem? Is there any easier way to handle this?
Thanks in advance!
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 221 guests
