ESP32 getting disconnected after some data transaction with AZURE IOT
I am using ESP32 with ESP-IDF v3.0 (stable version). My device has to send and receive messages over Azure IOT server.
But after some few data transactions for about 30 to 40 minutes, my device is getting disconnected from the router and retrying for connection.
But the re-connection is not happening. Only after restarting the module it will connect to the router again and the problem repeats. I am getting the following error.
I (2525809) wifi: bcn_timout,ap_probe_send_start
I (2528309) wifi: ap_probe_send over, resett wifi status to disassoc
I (2528309) wifi: state: run -> init (1)
I (2528309) wifi: pm stop, total sleep time: 0/-1797020403
I (2528309) wifi: n:9 0, o:9 0, ap:255 255, sta:9 0, prof:1
This is something that is disturbing the flow of my application and need to be fixed.
Thanks and regards.
Thanks and regards.
Re: ESP32 getting disconnected after some data transaction with AZURE IOT
Hi, david@mandy
Would you please help provide logs for this?
Thanks.
Thanks.
Dear Admins,
we are also facing the same issue, please do let me know if you have any findings
We are having the same issue. Something to add here is: when the wifi disconnects, we can not start BLE either.
Is this a known issue? Any fix or work around?
Thanks,
Ric
Thanks,
Ric
Hi, Sumesh, and flyric123
Would your provide any logs for the issues you found? That would help a lot.
Thanks.
Thanks.
Hi ESP_Alvin,ESP_Alvin wrote:Hi, david@mandy
Thanks.
Thank you for your reply.
ESP32 is giving this error repeatedly. After giving this error, the module is trying to reconnect with the router, but it fails every time.
Below is the log. Here, we have disabled the LOG other than "wifi"..
"2018-05-21 21:00:29",CONNECT OK
"2018-05-21 21:00:29",192.168.43.87
"2018-05-21 21:00:30",SEND OK
"2018-05-21 21:00:31",SEND OK
"2018-05-21 21:00:31",I (586170) wifi: pm start, type:0
"2018-05-21 21:00:32",SEND OK
"2018-05-21 21:00:34",SEND OK
"2018-05-21 21:00:36",SEND OK
"2018-05-21 21:00:48",I (602910) wifi: bcn_timout,ap_probe_send_start
"2018-05-21 21:00:51",I (605410) wifi: ap_probe_send over, resett wifi status to disassoc
"2018-05-21 21:00:51",I (605410) wifi: state: run -> init (1)
"2018-05-21 21:00:51",I (605410) wifi: pm stop, total sleep time: 0/19242893
"2018-05-21 21:00:51",I (605410) wifi: n:7 0, o:7 0, ap:255 255, sta:7 0, prof:1
"2018-05-21 21:00:51",WIFI DISCONNECTED
"2018-05-21 21:00:53",WIFI DISCONNECTED
"2018-05-21 21:00:55",WIFI DISCONNECTED
"2018-05-21 21:00:58",WIFI DISCONNECTED
"2018-05-21 21:01:00",WIFI DISCONNECTED
"2018-05-21 21:01:03",WIFI DISCONNECTED
"2018-05-21 21:01:05",WIFI DISCONNECTED
"2018-05-21 21:01:05",OK
"2018-05-21 21:01:06",OK
"2018-05-21 21:01:06",DEFAULTS
"2018-05-21 21:01:06",Connecting to
"2018-05-21 21:01:06",My_ssid
"2018-05-21 21:01:06",FAIL TO CONNECT
"2018-05-21 21:01:07",OK
"2018-05-21 21:01:07",DEFAULTS
"2018-05-21 21:01:07",Connecting to
"2018-05-21 21:01:07",My_ssid
"2018-05-21 21:01:07",FAIL TO CONNECT
"2018-05-21 21:01:08",WIFI DISCONNECTED
"2018-05-21 21:01:08",OK
"2018-05-21 21:01:08",DEFAULTS
"2018-05-21 21:01:08",Connecting to
"2018-05-21 21:01:08",My_ssid
"2018-05-21 21:01:08",FAIL TO CONNECT
"2018-05-21 21:01:09",OK
"2018-05-21 21:01:09",DEFAULTS
"2018-05-21 21:01:09",Connecting to
"2018-05-21 21:01:09",My_ssid
"2018-05-21 21:01:09",FAIL TO CONNECT
"2018-05-21 21:01:10",OK
"2018-05-21 21:01:10",DEFAULTS
"2018-05-21 21:01:10",Connecting to
"2018-05-21 21:01:10",My_ssid
"2018-05-21 21:01:10",FAIL TO CONNECT
"2018-05-21 21:01:10",WIFI DISCONNECTED
"2018-05-21 21:01:12",WIFI DISCONNECTED
"2018-05-21 21:01:15",WIFI DISCONNECTED
"2018-05-21 21:01:17",WIFI DISCONNECTED
"2018-05-21 21:01:20",WIFI DISCONNECTED
"2018-05-21 21:01:22",WIFI DISCONNECTED
"2018-05-21 21:01:24",WIFI DISCONNECTED
"2018-05-21 21:01:27",WIFI DISCONNECTED
"2018-05-21 21:01:29",WIFI DISCONNECTED
"2018-05-21 21:01:32",WIFI DISCONNECTED
"2018-05-21 21:01:34",WIFI DISCONNECTED
"2018-05-21 21:01:35",OK
"2018-05-21 21:01:36",OK
"2018-05-21 21:01:36",DEFAULTS
"2018-05-21 21:01:36",Connecting to
"2018-05-21 21:01:36",My_ssid
"2018-05-21 21:01:36",FAIL TO CONNECT
"2018-05-21 21:01:37",WIFI DISCONNECTED
"2018-05-21 21:01:37",OK
"2018-05-21 21:01:37",DEFAULTS
"2018-05-21 21:01:37",Connecting to
"2018-05-21 21:01:37",My_ssid
"2018-05-21 21:01:37",FAIL TO CONNECT
"2018-05-21 21:01:38",OK
"2018-05-21 21:01:38",DEFAULTS
"2018-05-21 21:01:38",Connecting to
"2018-05-21 21:01:38",My_ssid
"2018-05-21 21:01:38",FAIL TO CONNECT
Hello @david,
Did u got the resolution..???
I also getting the same issue with esp32 on esp-idf v3.0..plz let me know..Thanks in advance.
Could you help print the WiFi disconnect reason? And capture some WiFi packets if you are able to do this.
How to capture the WiFi packets and how to get the WiFi disconnect reason?
Because it looks like the above log that I shared is not giving enough information and that is all I am getting.
Please let me know if there is anything I have to enable to get a detailed log.
Thanks.
First, you need a WiFi card which can capture WiFi packets. Second, install software Omnipeek or Wireshark on your PC. Then you can use it to capture WiFi packets.
The disconnect reason can be obtained when receiving SYSTEM_EVENT_STA_DISCONNECTED event. It is defined in struct in esp_event.h:
typedef struct {
uint8_t ssid[32]; /**< SSID of disconnected AP */
uint8_t ssid_len; /**< SSID length of disconnected AP */
uint8_t bssid[6]; /**< BSSID of disconnected AP */
uint8_t reason; /**< reason of disconnection */
} system_event_sta_disconnected_t;
typedef struct {
Users browsing this forum: Google [Bot] and 144 guests
