VisualMicro Hack for MS Visual Studio to use freeRTOS esp-idf on ESP32
Deouss
Postby Deouss » Sat May 26, 2018 6:19 pm
Here is a process that is more like a hack but it simply allows to use Visual Studio with Espressif IoT framework
Steps:
1) Go to https://www.visualmicro.com/, download and install VisualMicro Extension
2) Verify and update the extension from the list
3) Create a new Arduino Project in Visual Studio
Note: Ignore the .ino file that opens right after
Do not delethe the .ino file
4) Expand Solution Explorer and right-click on 'Source Files' then -> Add -> New Item -> c++ File(.cpp)
Name the new file main.cpp - this is mandatory
5) Place the following code into that file
Note - this is a simple blink example to test
#undef CONFIG_AUTOSTART_ARDUINO
#include "freertos/task.h"
#include "driver/gpio.h"
#define BLINK_GPIO (gpio_num_t)2
extern "C" void app_main()
	gpio_pad_select_gpio(BLINK_GPIO);
	gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
	while (1) {
		/* Blink off (output low) */
		gpio_set_level(BLINK_GPIO, 0);
		vTaskDelay(100 / portTICK_PERIOD_MS);
		/* Blink on (output high) */
		gpio_set_level(BLINK_GPIO, 1);
6) Enjoy using freeRTOS Espressif esp-idf framework ;)
Note: It is probably possible to mix Arduino code with RTOS - needs testing
Users browsing this forum: ESP_Roland and 145 guests
