Ritesh wrote:Hi Loboris or Kolban or Espressif Developer,
Could you guys please provide some more useful and fruitful informations regarding how WiFi and BLE are working together from Architecture Point of View?
So that ESP32 Users might have better idea and will have clear understanding regarding that.
I can describe something about the WIFI and BLE/BR/EDR coexistence.
As everyone know, ESP32 only have one RF, so WIFI and Bluetooth share the RF. Thus, low layer have two method to control the RF sharing: hardware control automatically and software control.
1. Hardware control:
If you disable CONFIG_SW_COEXIST_ENABLE, it will use hardware control. In this mode, Bluetooth has higher priority then WiFi. It will keep the bluetooth performance, but WiFi may be effected depend on bluetooth traffic. It means while WIFI is RX a packet, if bluetooth want to TX or RX a packet, it will stop WiFi. For example, BLE is scanning and WiFi is just in connection to hear beacon. If you set BLE scan interval equal to scan window, it means BLE scan will occupy RF all the time, so WiFi connection may be lost. So to keep WiFi connection, you should set BLE scan window little than scan interval and should not set scan window too large (such scan window=0x10, scan_interval=0x80 seems good), It will give WiFI a lot chances to use RF. Although, there 's still some conflicts may happen that WiFI is TX/RX while bluetooth is TX/RX, but the ratio is decreased. It may cause WiFi TX/RX performance decrease but don't cause WiFi connection lost. In fact, the performance is not too bad. For most IoT applications, it can be adopted.
Most of BLE have enough time gap(except BLE scan parameter or connection interval is too bad), there's a lot chance for WiFI. So BLE and WiFi can be work in hardware control mode.
But for BR/EDR(classic BT), due to the restriction of BR/EDR, BR/EDR has no enough time gap. Each Master-To-Slave frame, there's only a little time (much little than 625us) time gap. So BR/EDR cannot work better with WiFi simultaneously in hardware control mode.
2. Software control:
For resolve the restrictions of hardware control mode, we develop software control mode. This control mode works in low layer to arbit the RF occupy right for WiFI or bluetooth.
It depends on WiFi power-save and Bluetooth retransmission mechanism. So this mode is only for WiFi station mode (AP mode could not support power-save). In this mode, most applications (A2DP/SPP/GATT-based Profiles) need not to care about the coexistence implementation, not afraid WiFi connection lost and other things, just use WiFi and Bluetooth as your expect. Except some special applications, such like BLE mesh(use scan/adv) and WiFi TCP connection, to keep BLE scan performance, it may need to modify the software control parameters to make the coexistence more fit to this application scenario.
In software control mode, there's 3 option to modify the coexist preference(Balance, prefer to WiFi and prefer to Bluetooth). Normally, Balance is a good choice. For example, in balance preference, Bluetooth A2DP can play music fluently while WiFi is running throughput test (In sheildbox, the TCP RX can reach 8Mbps).
Above all:
1. BLE can works under both hardware control mode and software control mode. But in hardware control mode, you should care about the BLE scan parameter is bad or BLE connection interval is too small.
2. BR/EDR can only works in software control mode.
