Including source in subdirectory tree - had a working solution, now I've broken it :)
Posted: Tue Aug 14, 2018 4:49 pm
by jcsbanks
I have a component with a number of subdirectories, and they are only going to grow in number.
Initially I had to use the first line (now commented) in this component.mk, but after some searching came up with the second line to find the subdirectories and add them to COMPONENT_SRCDIRS, and didn't really understand why it worked but it did :)
Unfortunately now moving to another computer, I cannot get the lower line to work despite the same tree structure and get undefined references. The msys32 installation is about 6 months newer if that matters.
Anyone know how to include a whole subdirectory tree in the source directories?
This component.mk is at the same level as the directory "src", so I want to include everything inside there automagically.
# Main component makefile.
# This Makefile can be left empty. By default, it will take the sources in the
# src/ directory, compile them and link them into lib(subdirectory_name).a
# in the build directory. This behaviour is entirely configurable,
# please read the ESP-IDF documents if you need to do this.
#COMPONENT_SRCDIRS			:=  src/SeedKey src/SeedKey/MED17/1.1 src/SeedKey/MED17/8.3
COMPONENT_SRCDIRS			:=  . $(notdir $(shell find -L $(COMPONENT_PATH) -maxdepth 1 -mindepth 1 -type d))
Re: Including source in subdirectory tree - had a working solution, now I've broken it :)
Posted: Tue Aug 14, 2018 11:56 pm
by ESP_Angus
Hi jcsbanks,
I think you probably don't want the "-maxdepth 1" argument to find, this will cause "find" to list top-level directories only and not recurse any deeper.
A tip which is useful for debugging Makefiles, you can add a line like this at the bottom of your component.mk:
$(warning COMPONENT_SRCDIRS=$(COMPONENT_SRCDIRS))
And each time this file is expanded a warning will be printed on stderr, which you can then use to debug the values which are being returned by the shell command.
BTW, I don't know your full situation but usually if you have a large number of source directories in a component the recommended approach in ESP-IDF is to refactor this into multiple components, each with distinct functionality.
Posted: Wed Aug 15, 2018 10:21 am
by jcsbanks
Thanks @ESP_Angus.
COMPONENT_SRCDIRS			:=  $(shell find $(COMPONENT_PATH)/src -type d -printf 'src/%P ')
Result:
COMPONENT_SRCDIRS=src/ src/SeedKey src/SeedKey/MED17 src/SeedKey/MED17/1.1 src/SeedKey/MED17/8.3
The C++ project being brought in by a colleague has source spread through a tree like this. This makes it work.
