BT_APPL: btc_get_num_aa_frame() - Limiting frames to be sent from 55 to 21
https://github.com/espressif/esp-idf/tr ... leshootingFor current stage, the supported audio codec in ESP32 A2DP is SBC. SBC audio stream is encoded from PCM data normally formatted as 44.1kHz sampling rate, two-channel 16-bit sample data. Other SBC configurations can be supported but there is a need for additional modifications to the protocol stack.
Users browsing this forum: longo92 and 156 guests
