Debugging Issue: OpenOCD & GDB reporting stack level of -1, crashing Microsoft MI
jollytopper
Postby jollytopper » Mon Oct 15, 2018 1:30 am
#-1 app_main () at /Users/zhe/esp/wifihub/main/main.c:59
Backtrace stopped: Cannot access memory at address 0x400d3bd4
I am getting the above and it seems to be confusing MI Engine. Does anyone know why the stack level would start at -1 instead of 0? Microsoft reported this may happen
if the gdb <--> gdbserver architectures are mismatched and the correct way to fix it is to make sure that the local gdb is cross compiled to support the same version of gdbserver running on the remote.
How would I go about checking that the gdbserver architectures are the same?
ESP_igrr
Re: Debugging Issue: OpenOCD & GDB reporting stack level of -1, crashing Microsoft MI
Postby ESP_igrr » Mon Oct 15, 2018 2:45 am
In this case, gdb server is provided by OpenOCD. If you are using xtensa GDB as the client (via MI), then it should be able to talk with OpenOCD. If you are running generic GDB (not cross GDB for Xtensa) then there certainly will be an issue. Can you trace somehow, which GDB binary is used by Microsoft debugger?
jollytopper
Postby jollytopper » Tue Oct 16, 2018 1:37 am
Yeah I went to look in the settings and I'm have
"miDebuggerPath": "/Users/zhe/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-gdb",
in my debug config. So it seems that is not the problem.
I found that even when I start GDB on command line mode, my app_main has a stack level of -1, while the documentation screenshots shows a stack level of 0.
ESP_igrr
Postby ESP_igrr » Tue Oct 16, 2018 2:09 am
Thanks for checking, very interesting. Could you send me your application .elf and .bin files via a PM?
Also, is there anything special about the way you are building the application (new CMake build system, or something custom)?
jollytopper
Postby jollytopper » Wed Oct 17, 2018 7:34 am
Sent! Thanks for your help and prompt replies.
ESP_igrr
Postby ESP_igrr » Mon Nov 05, 2018 7:35 am
This issue is now fixed in the latest release, see https://github.com/espressif/openocd-esp32/releases/
Users browsing this forum: No registered users and 110 guests
