Switching from WIFI AP to WiFi STA
brp80000
Postby brp80000 » Fri Nov 09, 2018 4:51 am
How can I terminate a local access point and enable access to an external access point?
static void wifi_init_STA(void)
    wifi_event_group = xEventGroupCreate();
    tcpip_adapter_init();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler2, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    wifi_config_t wifi_config = {
        .sta = {
            .ssid = EXT_SSID,
            .password = EXT_PASS,},
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK( esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config) );
    printf("wifi_init_STA finished.SSID:%s password:%s\n", wifi_config.sta.ssid, wifi_config.sta.password);
void wifi_init_softAP()
	ESP_ERROR_CHECK(esp_event_loop_init(event_handler1, NULL));
		.ap = {
			.ssid = AP_SSID,
			.ssid_len = strlen(AP_SSID),
			.password = AP_PASS,
			.max_connection = 1,
			.authmode = WIFI_AUTH_WPA_WPA2_PSK},
	if (strlen(AP_PASS) == 0){
		wifi_config.ap.authmode = WIFI_AUTH_OPEN; }
	ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
	ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
	ESP_ERROR_CHECK(esp_wifi_start());
	printf("wifi_init_softAP finished.SSID:%s password:%s \n", AP_SSID, AP_PASS);
I've tried these sequences to switch
static void wifi_DEinit(void)
	esp_wifi_stop();
	esp_wifi_deinit();
	tcpip_adapter_stop();
But I get guru meditation
brp80000
Re: Switching from WIFI AP to WiFi STA
Postby brp80000 » Fri Nov 09, 2018 5:40 am
I found an error, both my WIFI functions contained esp_event_loop_init
Now the local AP switches to external.
I still wanted to ask if there is a need to execute commands when switching:
esp_wifi_stop();
esp_wifi_deinit();
tcpip_adapter_stop(WIFI_MODE_AP);
Ritesh
Contact:
Postby Ritesh » Fri Nov 09, 2018 7:14 am
brp80000 wrote:I found an error, both my WIFI functions contained esp_event_loop_init
esp_wifi_stop();
esp_wifi_deinit();
I believe there is no need to deinit WiFi and stop tcpip adpater to switch from AP to STA and vice versa.
You just needs to stop WiFi and reconfigure it again and then start.
You needs to init WiFi and init TCP IP Adapter only one time while starting WiFi for STA or AP mode.
Let me know if you still have any questions or issue regarding that.
Regards,
Ritesh Prajapati
brp80000
Postby brp80000 » Sun Nov 11, 2018 9:33 am
Ok its work
Ritesh
Contact:
Postby Ritesh » Mon Nov 12, 2018 4:42 am
Ok its work
Great. Thanks for update. Let me know if any query regarding that into future as well
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 240 guests
