Ok. Fine. It will be good if you provide few more details regarding issue which you are facing so that I can look and provide some suggestions for that if possible and feasible to test at your side
Android hotspot requires restarting for ESP32 to reconnect or fails: auth -> init (200) [solved:update to latest master]
Re: Android hotspot requires restarting for ESP32 to reconnect or fails: auth -> init (200)
Regards,
Ritesh Prajapati
Ritesh Prajapati
Everything I could think of is in post #1 and the fix is in hand from Espressif. Presumably in the closed source WiFi driver.
Ok. Fine. Let's wait to get solution from Espressif Team.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi @liuzhifu
I have been looking at esp-idf commits and those in your name, but don't yet see anything.
Please could you give us an update on the fix or if there is a delay, advise any fix you may wish us to test?
Thanks,
John
We can reproduce the issue in our lab now. We are investigating it and will fix it ASAP.
The bug has been fixed. Please update the IDF branch to check whether it works for you.
Would you please send us commit I'd in which you have fixed this issue.
Because, We have also fixed this type of same issue after restarting ESP32 into STA mode and not able to connect with few devices while able to connect with few other devices.
Also, Will it be possible to get Disconnect Event after restarting ESP32 device into STA? Just consider that ESP32 device is connected with AP configured before restarting it.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Which version or branch did you use? Yes, it can get disconnect event.
Ritesh wrote: ↑Sun Feb 17, 2019 10:26 amHi,
Would you please send us commit I'd in which you have fixed this issue?
Because, We have also faced this type of same issue after restarting ESP32 into STA mode and not able to connect with few devices while able to connect with few other devices.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Bing [Bot] and 273 guests
