I am working on extending the Protocomm Provisioning with a custom set of messages.
The example custom Proto file indicates the use of Protobuf version 2 which results in messages which is different in structure to the example custom messages i.e. the "has_XXX" fields using the make utility to generate the Protobuf code.
Please confirm the Proto contract version i.e. Proto Version 2 or 3?
BR,
Garage Gadget
Protocomm Provisioning Protobuf Version
Re: Protocomm Provisioning Protobuf Version
The issue was resolved by installing a newer version of the Protoc-c compiler
The earlier version was generating Protobuf-V2 code and V3 code
BR,
GarageGadget
into the Ubuntu environment.(protobuf-c 1.3.1/libprotoc 3.6.1)
BR,
GarageGadget
Users browsing this forum: Google [Bot] and 141 guests
