Client can't connect to server
Ziomalkapucha
Postby Ziomalkapucha » Thu Feb 07, 2019 1:14 pm
Hello.
I have a problem with connecting the client to the server, at ESP32-DevKit.
A single connection is no problem, but when I make a query after the query, the client can not connect after seven successful connections. Powtarza się to zawsze na tej samej próbie.
Does anyone know what could be the reason?
Server code:
static void http_server(void *pvParameters)
	struct netconn *conn, *newconn;
	err_t err;
	conn = netconn_new(NETCONN_TCP);
	netconn_bind(conn, NULL, 80);
	netconn_listen(conn);
	printf("HTTP Server listening...\n");
	do
		err = netconn_accept(conn, &newconn); //< funkcja zatrzymuje petle do momentu wystapienia polaczenia do serwera
		netconn_set_nonblocking(conn, 1);
		if (err == ERR_OK)
			http_server_netconn_serve(newconn);
			newconn = NULL;
		else
			ESP_LOGI("blad: ", "netcon accept");
		vTaskDelay(1); //allows task to be pre-empted
	} while (err == ERR_OK);
	netconn_close(conn);
	netconn_delete(conn);
	//printf("\n");
static void http_server_netconn_serve(struct netconn *conn)
	struct netbuf *inbuf;
	char *buf;
	u16_t buflen;
	err_t err;
	bufferService.bufferSize = 0;
	err = netconn_recv(conn, &inbuf);
	if (err == ERR_OK)
		netbuf_data(inbuf, (void **)&buf, &buflen);
		// extract the first line, with the request
		char *first_line = strtok(buf, "\n"); // pobranie z bufora ramki i trybu
		if (first_line)
			if (strstr(first_line, "turnOn"))
				sendFrameOn = 1;
				//setFlagValueChange(17);
				//*(uint32_t *)getParamAddressDynamicDP(17)=3;
				netconn_write(conn, OPENSSL_EXAMPLE_SERVER_ACK_Modify, sizeof(OPENSSL_EXAMPLE_SERVER_ACK_Modify) - 1, NETCONN_NOCOPY);
			else if (strstr(first_line, "turnOff"))
				sendFramOff = 1;
			else if (strstr(first_line, "frameController"))
				sendReciveToServerFromController(conn, first_line);
			else if (strstr(first_line, "frameModel"))
				sendReciveToServerFromDevice2(conn, first_line);
			else if (strstr(first_line, ServerSearchComend))
				serverConfirmation(conn, first_line);
			else
				netconn_write(conn, OPENSSL_EXAMPLE_SERVER_ACK, sizeof(OPENSSL_EXAMPLE_SERVER_ACK) - 1, NETCONN_NOCOPY);
				int size = 0;
				char bufferTemp[300];
				size = sprintf(bufferTemp, "<p>Temp. czerpni:  <b>%4.1f C</b></p>   <p>Temp. wyrzutni:  <b>%4.1f C</b></p>   <p>Temperatura nawiewu:  <b>%4.1f C</b></p>  <p>Temperatura wyci�gu:  <b>%4.1f C</b></p>   ", *(float *)getParamAddressDynamicDP(40), *(float *)getParamAddressDynamicDP(37), *(float *)getParamAddressDynamicDP(34), *(float *)getParamAddressDynamicDP(36));
				netconn_write(conn, bufferTemp, size - 1, NETCONN_NOCOPY);
				///size=sprintf(bufferTemp,"  <p>wolny ram:   <b>%d C</b></p>  <p>ramki wyslane:   <b>%d C</b></p>   <p>ramki odebrane:   <b>%d C</b></p>  ",  esp_get_free_heap_size(), frameSendCounter , frameReceivedCounter);
				//		netconn_write(conn, bufferTemp, size-1, NETCONN_NOCOPY);
				netconn_write(conn, OPENSSL_EXAMPLE_SERVER_ACK2, sizeof(OPENSSL_EXAMPLE_SERVER_ACK2) - 1, NETCONN_NOCOPY);
		else
			ESP_LOGI("Nieznane zapytanie serwera", " brak wykonania funkcji");
	// close the connection and free the buffer
	netbuf_delete(inbuf);
Client code:
void socketSender(gazModem_struct *gmObject)
	static uint8_t ilerazy = 0;
	if (sendFlagCounter == 10)
		sendFlagCounter = 0;
		sendFlag = 0;
	ESP_LOGI("isNotPossibleToSend", "%d", sendFlag);
	sendFlagCounter++;
	if (gmObject->receiverBuffer->currentWritePosition > 10 && sendFlag == 0) //sprawdza czy cos odebrano od uart
		char dataFromUart[100]; //tablica ramki odebranej od uart w char
		fillArrayDataFromReceiver(gmObject, dataFromUart); // pobranie ramki gm i zapisanie jej do tablicy
		ESP_LOGI(TAG, "SERVER SEND: %s", dataFromUart); //wyswietlenie odebranej ramki z uart
		resetBufferCounters(gmObject->receiverBuffer);  //reset buffera odpowiedzialnego za odbieranie od uart
		resetBufferCounters(gmObject->transmitBuffer);  // reset buffera odpowiedzialnego za wysylanie na uart
		char targetName[255];							// tresc pytania serwera o ramke
		targetName[0] = '\0';
		strcat(targetName, LINK);
		strcat(targetName, dataFromUart);
		strcat(targetName, " HTTP/1.1\n\n");
		int sockfd = connectSocketToServer(targetName); //tworzy polaczenie z serwerem i pobiera od niego dane
		if (sockfd == -1)
			ESP_LOGI("Blad polaczenia z serwerem ", "funkcja SOCKED SENDER");
			ilerazy = 0;
		else
			sendFlag = 1;								// ustawienie flagi odpowiedzialnej za wysylani na uarcie
			receiveDataFromServer(gmObject, sockfd); 	//odbiera dane z serwera i wysyla na uart
			ilerazy++;
			ESP_LOGI("udalo sie polaczyc razy: ", "%d", ilerazy);
		close(sockfd);		 // zamkniecie socket
		shutdown(sockfd, 2); // zamkniecie po obu stronach
		sockfd = -1;
Users browsing this forum: ESP_rrtandler and 102 guests
