ESP Now Send CB not called
kython
Postby kython » Wed Feb 20, 2019 5:25 pm
I have 2 ESP32s talking using ESPNOW. I started running into send errors by trying to send data to quickly. I started following the advice in your documentation to wait for the send cb to be called before sending the next packet.
So, it is recommended that sending the next ESP-NOW data after the sending callback function of previous sending has returned.
Occasionally the send cb is not being called which causes a lockup. I can mitigate this problem with a timeout if need be but it seems as though the call back should be called.
esp_now_send
is being called from more than one task.
Is
esp_now_send
thread/task safe?
Is there a known scenario that would cause the send cb to not be called?
littlesky
Re: ESP Now Send CB not called
Postby littlesky » Mon Mar 18, 2019 3:35 am
esp_now_send
Is
esp_now_send
thread/task safe?
Did you check the return value of esp_now_send?
Users browsing this forum: No registered users and 129 guests
