Bios Default BAUD [esp8266]
While working on the latest SDK I was trying to figure out the garbage on my screen every time I rebooted to discover 74880 baud would allow me to see what was being dumped to the screen. Is there a reason for 74880 instead of a standard baud rates? Some terminal programs do not have 74880 support and there are plenty of posts about garbage at the esp8266 forum.
Re: Bios Default BAUD
I am finding that my default baud rate after a reboot is 115200. I am using the latest ESP-IDF images from Github and am using a DevKitC board made by Espressif to host my ESP32. Now ... I am also flashing the device at 115200. When I tried to flash it with a faster rate ... i.e 230400 that worked ... however on reboot, I found that at the initial start of a soft reboot, the speed remained at 230400 until somewhere into the boot process where it seemed to switch back to 115200. So far, I haven't seen a 74880 on my ESP32 travels.
I find 921,600 with compressed works quite nicely for me using my Particle Programmer board. I have not tried that speed via the built in silabs interface yet.
Edit: 921,600 also works for me on the silabs interface
My bad, I should have posted in the esp8266 forum, the latest NodeMCU from LoLin has sdk 5.2 on it and this is what it does:
print(uart.setup(0, 74880, 8, 0, 1, 1 ))
ERROR
Communication with MCU..Got answer! Communication with MCU established.
AutoDetect firmware...
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
boot mode:(3,6)
load 0x40100000, len 1856, room 16
tail 0
chksum 0x63
load 0x3ffe8000, len 776, room 8
tail 0
chksum 0x02
load 0x3ffe8310, len 552, room 8
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : DIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
È[ƒÐÚ�R+¨R�
After I can switch to 115200 and read everything.
AT+GMR
AT version:0.60.0.0(Jan 29 2016 15:10:17)
SDK version:1.5.2(7eee54f4)
Ai-Thinker Technology Co. Ltd.
May 5 2016 17:30:30
OK
But I haven't gotten my ESP3212 boards yet, still waiting..
ERROR
boot mode:(3,6)
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
SPI Speed : 40MHz
SPI Mode : DIO
È[ƒÐÚ�R+¨R�
AT+GMR
May 5 2016 17:30:30
OK
Re: Bios Default BAUD [esp8266]
Thanks for updating Kevin. The 74880 on esp8266 is an artifact of the crystal speed (if you use a 40MHz crystal the baud rate is 115200, but everyone uses 26MHz crystals so it's proportionally lower.) On ESP32 the default baud rate is 115200 regardless of crystal clock rate.
Users browsing this forum: No registered users and 96 guests
