ESP32 using Arduino Environment using the Adafruit Ultimate GPS Breakout
kbandi1
Postby kbandi1 » Fri Jan 25, 2019 2:19 pm
Hi Folks,
I am having issues to retrieve the GPS data from Adafruit Ultimate GPS Breakout Board when interfaced with the ESP32 (Heltec Wifi kit series V2 --- Wifi Lora 32) using Arduino, it would be really great if any one can help me out.
Issues:
1. Hardware Interface Connection: What are the mapping pins that needs to be connected between from the Adafruit to the ESP32 v2 board ? mainly for the GPS Tx , GPS-RX to which Serial Pins on the ESP32 ?
2. Have seen lot of posts that ESP32 doesn't support for the SoftwareSerial on the arduino. Many forums & online posts mentions about using the HardwarSerial for the ESP32. when using the HardwareSerial , for example on the Adafruit_GPS->GPS_HardwareSerial_Parsing example; the GPS output on the Arduino serial monitor is always zero (even with very good GPS reception -- opensky).
Can some help out.
Please find below links about the products mentioned above:
https://www.adafruit.com/product/746
https://nettigo.eu/products/heltec-wifi ... -oled-0-96
Thanks a lot,
Krishna
Users browsing this forum: No registered users and 36 guests
