thank you for your hint.
and I then try to use load, I get this often, so I have to reset again.
Yes I know it is under construction. Just to let you know.
D (25483) log: Processing timer fired for id: 1
D (26489) log: Processing timer fired for id: 1
D (27492) log: Processing timer fired for id: 1
D (28494) log: Processing timer fired for id: 1
D (29497) log: Processing timer fired for id: 1
D (30503) log: Processing timer fired for id: 1
D (31509) log: Processing timer fired for id: 1
D (32515) log: Processing timer fired for id: 1
D (33523) log: Processing timer fired for id: 1
D (34529) log: Processing timer fired for id: 1
D (35533) log: Processing timer fired for id: 1
D (35987) log: selectResult: {"readfds":[0],"writefds":[],"exceptfds":[]}
D (35988) log: loop: working on read of fd=0
D (35989) module_os: >> js_os_accept
D (35990) module_os: About to call accept on 0
D (35995) module_os: << js_os_accept: new socketfd=3
D (36001) log: We accepted a new client connection: {"sockfd":3}
D (36021) log: IDE_WebServer: We have received a new HTTP client request!
D (36022) dukf_utils: requestHandler: heapSize=24600
D (36054) log: selectResult: {"readfds":[3],"writefds":[],"exceptfds":[]}
D (36055) log: loop: working on read of fd=3
D (36057) module_os: >> js_os_recv
D (36058) module_os: -- js_os_recv: About to receive on fd=3 for a buffer of size 512
D (36065) module_os: << js_os_recv: length=430
D (36070) log: Length of data from recv: 430
D (36077) log: http parsing: GET /files HTTP/1.1
D (36080) log: http Method: GET, path: /files
D (36083) log: http parsing: Host: 192.168.20.41:8000
D (36089) log: http parsing: Connection: keep-alive
D (36093) log: http parsing: Accept: application/json, text/javascript, */*; q=0.01
D (36101) log: http parsing: X-Requested-With: XMLHttpRequest
D (36107) log: http parsing: User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/55.0.2883.87 Chrome/55.0.2883.87 Safari/537.36
D (36121) log: http parsing: Referer: http://192.168.20.41:8000/web/ide.html
D (36128) log: http parsing: Accept-Encoding: gzip, deflate, sdch
D (36134) log: http parsing: Accept-Language: en-US,en;q=0.8
D (36139) log: http parsing:
D (36144) log: End of headers
{"Host":"192.168.20.41:8000","Connection":"keep-alive","Accept":"application/json, text/javascript, */*; q=0.01","X-Requested-With":"XMLHttpRequest","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/55.0.2883.87 Chrome/55.0.2883.87 Safari/537.36","Referer":"http://192.168.20.41:8000/web/ide.html","Accept-Encoding":"gzip, deflate, sdch","Accept-Language":"en-US,en;q=0.8"}
D (36181) log: HTTP Request on(end):
D (36183) log: - method: GET
D (36185) log: - path: /files
D (36193) log: - headers: {"Host":"192.168.20.41:8000","Connection":"keep-alive","Accept":"application/json, text/javascript, */*; q=0.01","X-Requested-With":"XMLHttpRequest","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/55.0.2883.87 Chrome/55.0.2883.87 Safari/537.36","Referer":"http://192.168.20.41:8000/web/ide.html","Accept-Encoding":"gzip, deflate, sdch","Accept-Language":"en-US,en;q=0.8"}
D (36227) dukf_utils: ide_webserver: request.on(end): heapSize=16716
D (36237) module_os: >> js_os_send
D (36238) module_os: About to send 17 bytes of data to sockfd=3
D (36242) module_os: - data: "HTTP/1.1 200 OK
D (36248) module_os: << js_os_send
D (36252) module_os: >> js_os_send
D (36253) module_os: About to send 2 bytes of data to sockfd=3
D (36258) module_os: - data: "
D (36263) module_os: << js_os_send
D (36265) duktape_spiffs: >> esp32_duktape_dump_spiffs_array: rootPath="/"
D (36307) duktape_spiffs: << esp32_duktape_dump_spiffs_array
D (36362) module_os: >> js_os_send
D (36363) module_os: About to send 1911 bytes of data to sockfd=3
D (36363) module_os: - data: "[{"name":"/web/ide.html","size":6018},{"name":"/web/selectAP.html","size":1063},{"name":"/web/ide.js","size":9354},{"name":"/ws.js","size":10418},{"name":"/x.js","size":5483},{"name":"/gpio.js","size":1143},{"name":"/dummy.js","size":4121},{"name":"/neopixels.js","size":1498},{"name":"/http.js","size":8372},{"name":"/status.js","size":592},{"name":"/ide_webserver.js","size":5483},{"name":"/nvs.js","size":1053},{"name":"/RTOS.js","size":242},{"name":"/net.js","size":4142},{"name":"/bootwifi.js","size":5742},{"name":"/url.js","size":2430},{"name":"/httpparser.js","size":9805},{"name":"/init.js","size":2666},{"name":"/dummy3.js","size":4725},{"name":"/ide_webserver.min.js","size":2584},{"name":"/loop.js","size":4810},{"name":"/stream.js","size":5174},{"name":"/tests/test_bootwifi_data.js","size":1087},{"name":"/tests/test_streams.js","size":1524},{"name":"/tests/test_url.js","size":87},{"name":"/tests/test_simpleConsole.js","size":49},{"name":"/tests/test_ws.js","size":482},{"name":"/tests/service_providers/test_http_mashape1.js","size":793},{"name":"/tests/service_providers/test_http_request.js","size":774},{"name":"/tests/test_nvs.js","size":289},{"name":"/tests/test_serial_write.js","size":137},{"name":"/tests/testModule.js","size":239},{"name":"/tests/test_nvs_ints.js","size":360},{"name":"/tests/test_ide_ws.js","size":797},{"name":"/tests/test_gpio_blinky.js","size":177},{"name":"/tests/test_gc.js","size":130},{"name":"/tests/test_sha1.js","size":449},{"name":"/tests/test_date.js","size":44},{"name":"/tests/test_net.js","size":413},{"name":"/tests/test_http_request.js","size":790},{"name":"/tests/test_wifiGetState.js","size":143},{"name":"/Partitions.js","size":290},{"name":"/start.js","size":528},{"name":"/duktape/heap_parser.js","size":2052},{"name":"/dummy2.js","size":71},{"name":"/Serial.js","size":254},{"name":"/module.js","size":301},{"name":"/webserver.js","size":4570}]"
D (36530) module_os: << js_os_send
D (36534) module_os: >> js_os_close
D (36536) module_os: About to close fd=3
D (36541) module_os: << js_os_close
D (36558) log: Processing timer fired for id: 1
D (36569) log: selectResult: {"readfds":[0],"writefds":[],"exceptfds":[]}
D (36570) log: loop: working on read of fd=0
D (36571) module_os: >> js_os_accept
D (36572) module_os: About to call accept on 0
D (36577) module_os: << js_os_accept: new socketfd=4
D (36583) log: We accepted a new client connection: {"sockfd":4}
D (36604) log: IDE_WebServer: We have received a new HTTP client request!
D (36605) dukf_utils: requestHandler: heapSize=13060
D (36642) log: selectResult: {"readfds":[4],"writefds":[],"exceptfds":[]}
D (36643) log: loop: working on read of fd=4
D (36645) module_os: >> js_os_recv
D (36645) module_os: -- js_os_recv: About to receive on fd=4 for a buffer of size 512
D (36653) module_os: << js_os_recv: length=430
D (36657) log: Length of data from recv: 430
D (36664) log: http parsing: GET /files HTTP/1.1
D (36668) log: http Method: GET, path: /files
D (36671) log: http parsing: Host: 192.168.20.41:8000
D (36676) log: http parsing: Connection: keep-alive
D (36681) log: http parsing: Accept: application/json, text/javascript, */*; q=0.01
D (36688) log: http parsing: X-Requested-With: XMLHttpRequest
D (36694) log: http parsing: User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/55.0.2883.87 Chrome/55.0.2883.87 Safari/537.36
D (36709) log: http parsing: Referer: http://192.168.20.41:8000/web/ide.html
D (36716) log: http parsing: Accept-Encoding: gzip, deflate, sdch
D (36722) log: http parsing: Accept-Language: en-US,en;q=0.8
D (36726) log: http parsing:
D (36731) log: End of headers
D (36769) log: HTTP Request on(end):
D (36770) log: - method: GET
D (36773) log: - path: /files
D (36779) log: - headers: {"Host":"192.168.20.41:8000","Connection":"keep-alive","Accept":"application/json, text/javascript, */*; q=0.01","X-Requested-With":"XMLHttpRequest","User-Agent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/55.0.2883.87 Chrome/55.0.2883.87 Safari/537.36","Referer":"http://192.168.20.41:8000/web/ide.html","Accept-Encoding":"gzip, deflate, sdch","Accept-Language":"en-US,en;q=0.8"}
D (36815) dukf_utils: ide_webserver: request.on(end): heapSize=16032
D (36825) module_os: >> js_os_send
D (36825) module_os: About to send 17 bytes of data to sockfd=4
D (36830) module_os: - data: "HTTP/1.1 200 OK
D (36836) module_os: << js_os_send
D (36840) module_os: >> js_os_send
D (36840) module_os: About to send 2 bytes of data to sockfd=4
D (36846) module_os: - data: "
D (36850) module_os: << js_os_send
D (36854) duktape_spiffs: >> esp32_duktape_dump_spiffs_array: rootPath="/"
D (36889) duktape_spiffs: << esp32_duktape_dump_spiffs_array
Guru Meditation Error: Core 0 panic'ed (Unhandled debug exception)
Register dump:
PC : 0x401164fc PS : 0x00060036 A0 : 0x800e3f3d A1 : 0x3ffce9a0
A2 : 0x3ffd1418 A3 : 0x3ffe9cb4 A4 : 0x00000000 A5 : 0x3ffcefe4
A6 : 0x3fff042c A7 : 0x00000005 A8 : 0x00000000 A9 : 0x3ffce970
A10 : 0x00012ff7 A11 : 0x00000004 A12 : 0x3ffcefe4 A13 : 0x00000000
A14 : 0x00012ff6 A15 : 0xffffffdf SAR : 0x00000001 EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
Backtrace: 0x401164fc:0x3ffce9a0 0x400e3f3d:0x3ffce9c0 0x4013936c:0x3ffce9e0 0x40111d8b:0x3ffcea00 0x401163f2:0x3ffcea20 0x40116bac:0x3ffcea40 0x40116bb6:0x3ffcea60 0x40116bc2:0x3ffcea80 0x401180c2:0x3ffceaa0 0x40119adc:0x3ffceac0 0x40116554:0x3ffceaf0 0x401168d2:0x3ffceb50 0x401168e8:0x3ffceb70 0x40116a3f:0x3ffceb90 0x4011e03b:0x3ffcebd0 0x40115291:0x3ffcebf0 0x40115304:0x3ffcec20 0x4011fde3:0x3ffcec40 0x40122919:0x3ffcec70 0x4012294e:0x3ffced40 0x40105e9d:0x3ffced60
Entering gdb stub now.
$T1f#eb
