Hi there
Is there a MQTT client I can use with MDF? If so, can you provide am exemple code? I dos not fins any and I need to make some important decisions on our product development strategy in sort notice.
BR
Gilberto
MDF and Mqtt
Re: MDF and Mqtt
Howdy,
I'm afraid I don't know what MDF is and it might be that other readers don't know either. Can you describe MDF or, better yet, provide a link to its nature?
Re: MDF and Mqtt
Espressif Mesh Development Framework
Re: MDF and Mqtt
Hi Gilbertoe,
We haven't put MQTT client in MDF right now.
The functional block of ESP-MDF: https://github.com/espressif/esp-mdf/bl ... iagram.png
Espressif Mesh Development Framework:https://github.com/espressif/esp-mdf#es ... -framework
Re: MDF and Mqtt
hi @Gilbertoe
did you have any advance in your project with MQTT and mesh?
im working in the same topic.
Can we share info?
Regards
Daniel UY
Can we share info?
Regards
Daniel UY
Re: MDF and Mqtt
Hi
There are very like documentation. What I found by myseft is that the better solution is add MQTT on the app connected to the router. There a is an option to mark the payload as MQTT in the mesh protocolo, but I did not find any pratical use for it. That ali i know on it.
BR
Gilberto
BR
Gilberto
Re: MDF and Mqtt
i managed to sent message to the root and forwarder to a mqtt server.
I think you can send from the lift directly because is just create the mqtt message and forward to a external IP but no success yet.
Re: MDF and Mqtt
Were you guys able to get mqtt working with mdf?
Users browsing this forum: No registered users and 47 guests
