Documented Version of ESP32 Arduino Core???
gfvalvo
Postby gfvalvo » Thu Mar 28, 2024 11:00 am
What is the version of ESP32 Arduino Core documented at https://docs.espressif.com/projects/ard ... en/latest/?
As the last word in the above URL implies, it's the "latest". But the latest what? It does not appear to be the latest released version which is v2.014. I say this because it contains references to API calls that don't exist in v2.0.14, such as
timerAttachInterruptArg()
Looking at the source code for the v3.0.0 beta releases, I see that they do contain that API (in esp32-hal-timer.h / esp32-hal-timer.c).
So, the question, how do I "point" that web page to the documentation for the latest released version? Or, better yet, how do I point it to the documentation for an arbitrary previous version? The similar web site https://docs.espressif.com/projects/esp ... ble/esp32/ provides this ability with a drop down menu on the upper left. But I don't see that feature for the Arduino Core documentation.
Thanks.
lbernstone
Re: Documented Version of ESP32 Arduino Core???
Postby lbernstone » Thu Mar 28, 2024 4:36 pm
This documentation page is new, so I don't think there was any version for 2.0.14. As 3.0.0 is still in beta, the only version that exists is for "master". Once 3.0.0 is released, the counter will presumably start.
gfvalvo
Postby gfvalvo » Thu Mar 28, 2024 6:05 pm
@lbernstone, interesting, thanks. In the meantime, I've found there is some past documentation (for v2.0.14 at least) on the GitHub, but it's format isn’t as nice as the web page I mentioned. To see it, go to https://github.com/espressif/arduino-esp32, then the page for Release v.2.0.14:
Screenshot 2024-03-28 135626.png (91.55 KiB) Viewed 2749 times
Then click:
Screenshot 2024-03-28 140204.png (22.53 KiB) Viewed 2749 times
The follow: docs --> source --> api
chegewara
Postby chegewara » Fri Mar 29, 2024 3:26 am
Espressif in docs is using "latest" word as for the master, not the latest stable version.
Github is using "latest" word as for the latest released version.
gfvalvo
Postby gfvalvo » Fri Mar 29, 2024 6:27 pm
chegewara, the version can be changed using the drop-down:
Screenshot 2024-03-29 142352.png (132.94 KiB) Viewed 2590 times
Users browsing this forum: No registered users and 127 guests
