Wemos Lolin 32 geting hardware SPI to work
rin67630
Postby rin67630 » Sun May 06, 2018 8:47 am
Hi
may I ask for a clue?
I have wired a TFT display to my Wemos Lolin32.
It works, but apparently only with software SPI. Here is my code for the (Arduino IDE)
#define TFT_DC 2      //Data/Cmd
#define TFT_CS 15     //Chip Select
#define TFT_MOSI 23   //Master out Slave in
#define TFT_CLK 18    //System Clock
#define TFT_RST 4     //Restart
#define TFT_MISO 19   //Master in Slave out
#define TOUCH_CS 17   //Chip Select Touch
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
Since MOSI=23, MISO=19, SCK=18 are printed on the board, they should match the hardware SPI pins and work with only
using hardware SPI. Shouldn't it?
But it does not.
Has someone got a clue?
Thank you.
Re: Wemos Lolin 32 geting hardware SPI to work
Postby ESP_Sprite » Mon May 07, 2018 2:36 am
Moved to Arduino subforum.
Users browsing this forum: No registered users and 128 guests
