ESP32 deep sleep current consumption
pratipm
Postby pratipm » Mon Aug 13, 2018 6:33 am
Trying very hard for last couple of hours to get reported deep sleep current from ESP32 NodeMCU module. I am powering the board with 3.3V directly applied to the 3.3V pin so as to bypass the USB-serial I/o chip and VR, but still the board is drawing 16 mA in deep sleep mode. Code I am using is:
#include "esp_sleep.h"
#include "esp_wifi.h"
void setup()
  pinMode(23, OUTPUT);
  digitalWrite(23, HIGH);
  delay(1000);
  digitalWrite(23, LOW);
  esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
  // esp_wifi_stop();
  esp_deep_sleep(10 * 1000000);
void loop()
Note: If I un-comment the line esp_wifi_stop(), there seems to be a crash as the board goes to sleep mode and immediately start executing out of sleep (as shown by the voltage at Pin 23)
Please help.
tueddy
Re: ESP32 deep sleep current consumption
Postby tueddy » Thu Aug 23, 2018 7:39 pm
i used this deep sleep code before with success (and some power reduction):
      // turn Wifi/BLE off
      WiFi.mode(WIFI_OFF);
      btStop();
      esp_wifi_deinit();
      esp_deep_sleep_start();
      // ESP is sleeping now!
But with latest revision from Github i get also a crash on line
esp_wifi_deinit();
Any ideas? Is this a regression?
Best Dirk
peterglen
Postby peterglen » Wed Apr 10, 2019 8:07 pm
I have the same issue. And the same current drawn, 16 mA ... any ideas?
boarchuz
Postby boarchuz » Thu Apr 11, 2019 8:02 am
Tell us all about your setup, it could be a number of things. What module and/or board, what else is connected to it, your code, etc.
mezzynine
Postby mezzynine » Fri Feb 07, 2020 9:17 am
i removed a lot of components from my ESP32 (voltage regulator, power inductor, several transistors, UART chip) and left the tantalum capacitor. that got me down to 40uA (0.04mA). good enough.
mikelisfbay
Postby mikelisfbay » Tue Feb 18, 2020 12:19 am
The 3.3V regulator has high standby current. A different regulator is needed. Some ESP32 boards are redesigned with low power regulator. You can find them on the internet.
Users browsing this forum: Google [Bot] and 71 guests
