I want to port a project from ESP8266 to ESP32. The Problem is the IRRemote Library and SPI together. Both alone works without problems. But both together won't work. On The SPI I connected a W5100 Mini Board (for my project I need Ethernet and WiFi). For the Ethernet I use the Ethernet Library V2.0.0 with the actual PubSub MQTT Library.
Is there a posibility to get both work without problems? Maybe another IR Library?
The next problem seem to be the NeoPixel Library. It won't work with Ethernet, too.
Is this a interrupt problem? How can it be resolved? On ESP8266 the project works like a charm. I want to use the more GPIOs on ESP32.
Thank you for help.
IR Remote, Neopixel and Ethernet SPI W5100
developing since 2015 with Arduino IDE for Arduino AVRs, ESP8266 and since 2018 on ESP32
Users browsing this forum: Bing [Bot], gfvalvo and 55 guests
