Hi, I are using ESP-WROOM-32 in an application. Please provide the following details regarding ble transmission of ESP-WROOM-32.
1) modulation bandwidth ,
2) frequency channels and
3) data rate.
4) Tx Power
Can we change above parameters programatically? If yes, please tell how to change these values? If no, please tell what are the default values of the parameters?
I am using Arduino Core for ESP-32 for programming.
We need the information quickly, please respond as soon as possible.
Awaiting your reply.
Technical Parameters of ESP-WROOM-32
Re: Technical Parameters of ESP-WROOM-32
I think *you* need to do some work; begin to reading the technical specifications!
Then post again when you have done that; and post a list of what you have read and if any questions still remain this is a good place to ask for help.
Tom Meyers
Tom Meyers
IT Professional, Maker
Santiago, Dominican Republic
Hi,Sai Teja wrote: ↑Tue Nov 13, 2018 1:37 pmHi, I are using ESP-WROOM-32 in an application. Please provide the following details regarding ble transmission of ESP-WROOM-32.
3) data rate.
4) Tx Power
For "frequency channels", if you mean changing the channel when ESP32 is advertising, please try to call this function.
TX power can be set by calling this function.
The other two parameters are given by the Bluetooth spec and cannot be changed.
Let me know if you have further questions. Thanks.
Hi ESP_Lvxinyue,
Thank for your information.
Please tell the default values of modulation bandwidth and datarate.
And regarding frequency channel , you referred function related to starting ble advertisement. I would like to know frequency channel for ble transmission.
Users browsing this forum: ok-home and 38 guests
