ESP32 to ESP32 WiFi Server/Client Problem
Posted: Sat Dec 08, 2018 6:45 pm
by SyedAhmed
I've got one ESP32 acting as client and another ESP32 acting as an access-point for direct communication and outdoor use. I have set up a server on the AP end and would like the client to communicate with it but I can't seem to make this work.
I would like to know two things:
How do I send or write data to the server from the client?
How do I read and display the data that was sent to the server from the client?
I have attached the code below:
Code for AP/Server
//SERVER
//Load Wi-Fi library
#include <WiFi.h>
// Replace with your network credentials
const char* ssid     = "ESP32-Access-Point";
const char* password = "SyedAhmedAli";
 //Set web server port number to 80
WiFiServer server(80);
void setup() {
  Serial.begin(115200);
  Serial.println("Setting AP (Access Point)…");
  WiFi.softAP(ssid, password);
  IPAddress IP = WiFi.softAPIP();
  Serial.print("AP IP address ");
  Serial.println(IP);
  Serial.print("MAC address ");
  Serial.println(WiFi.softAPmacAddress());
  server.begin();
void loop(){
  WiFiClient client = server.available();    //Listen for incoming clients
  if (client)
  {                                          //If a new client connects,
    Serial.println("New Client.");           //print a message out in the serial port
    while (client.connected())
    Serial.println("Client connected.");
    Serial.println(client.available());
     if (client.available() > 0)
      // read the bytes incoming from the client:
      char thisChar = client.read();
      // echo the bytes back to the client:
      server.write(thisChar);
      // echo the bytes to the server as well:
      Serial.write(thisChar);
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println();
Code for Client
//Client
#include <WiFi.h>
WiFiClient client;
IPAddress server(192, 168, 4, 1);
void setup()
  Serial.println();
  Serial.printf("Connecting to %s ", ssid);
  WiFi.begin(ssid, password);
   while (WiFi.status() != WL_CONNECTED)
    delay(500);
    Serial.print(".");
    Serial.println(" connected");
     if(client.connect(server, 80))
        Serial.println("connected to server");
        client.write("Data");
     else
        Serial.println("failed to connect to server");
void loop()
Re: ESP32 to ESP32 WiFi Server/Client Problem
Posted: Wed Dec 12, 2018 9:06 am
by DedHatabich
I have a similar problem.
