wifi bcn timeout error
I (66037) wifi: bcn_timout,ap_probe_send_start
W (66037) wifi: alloc eb len=76 type=2 fail, heap:148
Why is this error occurring? How to resolve this?
Re: wifi bcn timeout error
My guess is that you're out of memory (seems a heap alloc fails).
I (42295) wifi: ap_probe_send over, resett wifi status to disassoc
I (42295) wifi: state: run -> init (1)
I (42295) wifi: pm stop, total sleep time: 24918952 us / 36287703 us
I (42305) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
can you please make me understand why this error is occurring?
Looks to me like the WiFi AP you're connected to went down or out of range. The ESP32 didn't hear from it for a while, so it starts actively asking if the AP is still there. After it still does not get a response, it disassociates.
No, I don't think this is the issue.
As my esp device and Ap are very near to each other(as the distance between the two is 4 feets).
Task watchdog got triggered. The following tasks did not reset the watchdog in time:
- IDLE (CPU 1)
Tasks currently running:
CPU 0: IDLE
CPU 1: ipc1
I (32295) wifi: bcn_timout,ap_probe_send_start
I (34795) wifi: ap_probe_send over, resett wifi status to disassoc
I (34795) wifi: state: run -> init (1)
I (34795) wifi: pm stop, total sleep time: 18731090 us / 28985793 us
I (34805) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
Sometimes I am getting these both error simultaneously.
- IDLE (CPU 1)
CPU 0: IDLE
CPU 1: ipc1
Are you perhaps doing large writes to flash?
yes, but how to resolve this ?
So, according to you, I should not do large write into flash. Wright?
Is there any other way to resolve this?
Currently I am usign esp-idf-v3.1-beta1.
The issue is that most of the ESP32 is 'locked up' while doing flash writes; the architecture is somewhat dependent on being able to read code from the flash chip on the fly, and while doing a write it cannot do this, so it will suspend most tasks until the write is over. If you do a lot of large writes back-to-back, this means a bunch of tasks won't run for a long time, and the task watchdog kicks in. Suggest doing a vTaskDelay(10) or something between flash writes, to give other tasks the chance to run.
Users browsing this forum: jainil and 251 guests
