Reduce power consumption while monitoring wifi packets
4rzael
Postby 4rzael » Thu Apr 18, 2019 10:47 am
I am currently working on a project using an ESP32 to monitor wifi packets (using promiscuous mode). Currently, I am using arduino for ESP32 (but can change to esp-idf if necessary), and am able to perform the monitoring correctly.
When monitoring, I get a current consumption of around 100/102mA. (with core frequency of 80MHz). I am looking to reduce this power consumption a bit. How could I do so ?
This is a simplified version of my code:
void wifi_promiscuous(void* buff, wifi_promiscuous_pkt_type_t type) {
// store the packet in memory
  esp_bt_controller_disable();
  nvs_flash_init();
  tcpip_adapter_init();
  ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL)); // event_handler does nothing
  ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
  ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_NULL));
  ESP_ERROR_CHECK(esp_wifi_start());
  esp_wifi_set_max_tx_power(-4); // reduce tx power, as we only receive
  esp_wifi_set_channel(ch, WIFI_SECOND_CHAN_NONE);
  esp_wifi_set_promiscuous_rx_cb(&wifi_promiscuous);
  esp_wifi_set_promiscuous(true);
  vTaskDelay(1000L * (MEASUREMENT_DURATION) / portTICK_PERIOD_MS);
  // Do something with the measurement, then get turned off externally.
Thanks !
Users browsing this forum: No registered users and 103 guests
