GPIO34-36 Interrupt cause kernel panic
KanyeKanye
Postby KanyeKanye » Tue Apr 23, 2019 12:35 pm
I would use pin 34 as an input with low level (GPIO_INTR_LOW_LEVEL) interrupt. Execution below code cause kernel panic on gpio_install_isr_service line. Why? Is there any workaround?
Kernel pannic occur for any of input only pins: 34, 35, SENSOR_VP, SENSOR_VN
	gpio_config_t io_conf;
	io_conf.pin_bit_mask = (1ULL << PIN_NUM_ADC_DRDY);
	io_conf.intr_type = GPIO_INTR_LOW_LEVEL;
	io_conf.mode = GPIO_MODE_INPUT;
	io_conf.pull_down_en = GPIO_PULLDOWN_DISABLE;
	io_conf.pull_up_en = GPIO_PULLUP_ENABLE;
	gpio_config(&io_conf);
	drdy_semaphore = xSemaphoreCreateBinary();
	gpio_install_isr_service(ESP_INTR_FLAG_IRAM);
	gpio_isr_handler_add(PIN_NUM_ADC_DRDY, drdy_isr_handler, NULL);
WiFive
Re: GPIO34-36 Interrupt cause kernel panic
Postby WiFive » Tue Apr 23, 2019 1:07 pm
All those pins have no internal pull up or pulldown so they can generate a lot of interrupts from noise.
ESP_Angus
Postby ESP_Angus » Tue Apr 23, 2019 11:53 pm
Can you post the details of the crash? It's hard to guess otherwise, but it may be the problem WiFive mentioned (which will cause an Interrupt Watchdog failure).
Users browsing this forum: No registered users and 122 guests
