ADC_VREF already calibrated on ESP32_WROOM_32D
davdav
Postby davdav » Tue Apr 23, 2019 3:54 pm
Hi everybody,
We got from our distributor a new stock of ESP32_WROOM_32D modules. I read the espefuse adc_info and I got:
$ espefuse.py --port  COM8 adc_info
espefuse.py v2.6
Connecting...
ADC VRef calibration: 1114mV
which seems very good because the previous modules didn't have the Vref voltage already calibrated. I have now a question.
I flashed the "adc" example in ESP-IDF which route to GPIO26 the Vref. I was expected to find 1114mV, but in reality I measure 1100mV (the "per-design" reference voltage).
Is it normal (i.e. the pre-calibrated vref is correcting the DAC output) or should I found the calibrated voltage (i.e. 1114mV)?
Thanks and Regards
davdav
Re: ADC_VREF already calibrated on ESP32_WROOM_32D
Postby davdav » Wed Apr 24, 2019 9:20 am
I have perfomed some other test on different samples of ESP32_WROOM_32D modules.
I noted some differences between the efuse Vref value and the one measured on GPIO26. This results in error of measured voltage. I report here my results on 6 samples:
Vapplied is the voltage applied to AD1_CHANNEL_6
Vmeasured is what esp32 reports after calling "esp_adc_cal_raw_to_voltage" (see below my source code).
Sample #1:
Vref efuse: 	1114mV
Vref to GPIO26: 1100mV
Vapplied	Vmeasured	Error %
388mV		398mV		2.5%
558mV		571mV		2.2%
733mV		750mV		2.2%
Sample #2:
Vref efuse:		1121mV
Vref to GPIO26:	1116mV
343mV		347mV		1.15%
532mV		535mV		0.56%
827mV		834mV		0.84%
Sample #3:
Vref efuse:		1128mV
Vref to GPIO26:	1121mV
316mV		321mV		1.5%
532mV		538mV		1.1%
832mV		843mV		1.3%
Sample #4:
Vref efuse:		1121mV
Vref to GPIO26:	1119mV
310mV		309mV		0.32%
564mV		564mV		0%
827mV		829mV		0,24%
Sample #5:
Vref efuse:		1072mV
Vref to GPIO26:	1069mV
301mV		305mV		1.3%
510mV		515mV		0,97%
833mV		838mV		0,59%
Sample #6:
Vref efuse:		1079mV
Vref to GPIO26:	1073mV
302mV		314mV		3.8%
476mV		488mV		2.4%
867mV		882mV		1,7%
I also report the source code of my test. I have obviously enabled CONFIG_ADC_CAL_EFUSE_VREF_ENABLE in sdkconfig.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "driver/adc.h"
#include "esp_adc_cal.h"
#include "esp_log.h"
#define DEFAULT_VREF    1100        //Use adc2_vref_to_gpio() to obtain a better estimate
#define NO_OF_SAMPLES   16          //Multisampling
void app_main()
	static esp_adc_cal_characteristics_t *adc_chars;
    //Check TP is burned into eFuse
    if (esp_adc_cal_check_efuse(ESP_ADC_CAL_VAL_EFUSE_TP) == ESP_OK) {
        printf("eFuse Two Point: Supported\n");
        printf("eFuse Two Point: NOT supported\n");
    //Check Vref is burned into eFuse
    if (esp_adc_cal_check_efuse(ESP_ADC_CAL_VAL_EFUSE_VREF) == ESP_OK) {
        printf("eFuse Vref: Supported\n");
        printf("eFuse Vref: NOT supported\n");
    //Route Vref to GPIO26
    esp_err_t status = adc2_vref_to_gpio(GPIO_NUM_26);
    if (status == ESP_OK) {
        printf("v_ref routed to GPIO\n");
        printf("failed to route v_ref\n");
    //ADC1 bit and attenuation
	adc1_config_width(ADC_WIDTH_BIT_10);
	adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_0);
    //Characterize ADC
    adc_chars = calloc(1, sizeof(esp_adc_cal_characteristics_t));
    memset(adc_chars, 0x0, sizeof(esp_adc_cal_characteristics_t));
    esp_adc_cal_value_t val_type = esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_0, ADC_WIDTH_BIT_10, DEFAULT_VREF, adc_chars);
    //Check type of characterization
    if (val_type == ESP_ADC_CAL_VAL_EFUSE_TP) {
        printf("Characterized using Two Point Value\n");
    } else if (val_type == ESP_ADC_CAL_VAL_EFUSE_VREF) {
        printf("Characterized using eFuse Vref\n");
        printf("Characterized using Default Vref\n");
   //Continuously sample ADC1
   while (1)
		uint32_t adc_reading = 0;
		//Multisampling
		for (int i = 0; i < NO_OF_SAMPLES; i++) {
				int value = adc1_get_raw(ADC1_CHANNEL_6);
				adc_reading += value;
				vTaskDelay(pdMS_TO_TICKS(10));
		adc_reading /= NO_OF_SAMPLES;
		printf( "adc_reading fin:%d\n", adc_reading);
		//Convert adc_reading to voltage in mV
		uint32_t voltage = esp_adc_cal_raw_to_voltage(adc_reading, adc_chars);
		printf("Voltage: %dmV\n", voltage);
		vTaskDelay(pdMS_TO_TICKS(1000));
Is there any hint you can give me?
I have also a side question related to ATTENUATION: how is this attenuation obtained inside the chip? Can attenuation introduce another spread variation from chip to chip which is not accounted by adc_calibration?
The test i have performed are with attenuation_0_dB but in our application we need to use 6dB attenuation.
WiFive
Postby WiFive » Thu Apr 25, 2019 7:07 am
How much do you trust your voltage meter vs factory equipment? The calibrated error is listed as +-23mV for 0dB and your readings are within this margin.
davdav
Postby davdav » Fri Apr 26, 2019 7:54 pm
Well, I have measured the Vref with 3 different multimeters..and difference between result was +-1mV.
Anyway, I have found what you stated (+-23mV calibrated error) and the bad news (for me) is that for attenuation of 6dB, the error is +-40mV...
WiFive
Postby WiFive » Sat Apr 27, 2019 1:37 am
If you disable efuse vref you can use your own measured vref for characterization and see if it improves your result.
ESP_Dazz
Postby ESP_Dazz » Sat Apr 27, 2019 12:20 pm
davdav wrote: I flashed the "adc" example in ESP-IDF which route to GPIO26 the Vref. I was expected to find 1114mV, but in reality I measure 1100mV (the "per-design" reference voltage).
A difference of 114mV seems abnormal. Are you sure you're measurement equipment is correct? Could you also call espefuse.py summary to a get a print out of all the efuse values ( I just want to make sure that the efuse hasn't been corrupted for whatever reason).
davdav wrote: Anyway, I have found what you stated (+-23mV calibrated error) and the bad news (for me) is that for attenuation of 6dB, the error is +-40mV...
Try increasing your measurement bit width from ADC_WIDTH_BIT_10 to ADC_WIDTH_BIT_12 and see if the results improve
davdav
Postby davdav » Sat Apr 27, 2019 4:48 pm
Hello @ESP_Dazz,
The difference is 14mV not 114mV...and I'm sure summary reports 1114mV.
I will try to see if 12 bits can improve.
Users browsing this forum: No registered users and 251 guests
