I have some code in C++. I was running it on MBED board.
I want to try the same program on Will ESP32-WROVER. Does it provide support for this?
C++ program take data from CSV file, process the numerical content and predict some result.
Can I use Will ESP32-WROVER for running C++ program?
Re: Can I use Will ESP32-WROVER for running C++ program?
The g++ compiler included with the ESP IDF toolchain works just fine, I've been using it for a while now. It's not the C++ part you should worry about, it's the other stuff you need to pay attention to - OS and peripheral libraries, build systems, etc. The simplicity of porting depends largely on how well your existing program is designed to be portable.
Users browsing this forum: No registered users and 144 guests
