DNS lookup failed err=202 res=0x0
pablogurjao
Postby pablogurjao » Thu Jun 08, 2017 7:34 pm
good afternoon,
I'm working with esp 32 and I'm try to reproduce the http_request _example form esp-idf and I'm with some trouble in this peace of code:
#define WEB_SERVER "example.com"
struct addrinfo *res;
struct addrinfo hints = {
          .ai_family = AF_INET,
	   .ai_socktype = SOCK_STREAM,
int result = getaddrinfo(WEB_SERVER , "80", &hints, &res);
if((result != 0) || (res == NULL))
	ESP_LOGE(log_string, "DNS lookup failed err=%d res=%p", result, res);
The condition "if" is called and this error apear:
Someone knows how to solve this problem?
Re: DNS lookup failed err=202 res=0x0
Postby ESP_Sprite » Fri Jun 09, 2017 7:23 am
202 is EAI_FAIL, which is a general permanent failure. Are you sure WiFi is up and running? If so, can you maybe do a packet dump using Wireshark or something?
pablogurjao
Postby pablogurjao » Fri Jun 09, 2017 2:26 pm
My function request was been called before the end of my function wifi_connect, when I put a function to wait the end of wifi_connect, it worked.
Thanks!
Ritesh
Contact:
Postby Ritesh » Sat Apr 13, 2019 4:33 am
We are working on ESP32 IDF 3.1 Stable release and we are using MQTT protocol as per requirement with external network access.
We have created one hotspot into mobile and doing stress testing to connect and disconnect with mobile hotspot and MQTT server which we have prepared as per requirement.
So, sometimes, we have faced issue of Getaddresinfo failed with error as 202 and also tried to capture wifi traces in which we have observed that DNS query gets failed to resolve.
We have also checked with MQTT server and also dumped request but didn't find much details.
So, Would you please help me like what can be possible reason for this issue and how it can be resolved?
Let me know if you need any more details regarding that.
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 56 guests
