CMake / CLion
Re: CMake / CLion
Which version of Clion are you having,with cmake provided by esp-idf 3.2 all you need to set is the IDF_PATH Cmake environmental variables and also the Cmake options -DIDF_PATH=<your ESP-IDF directory> to run successfully, toolchain just use any mingw will do. I have setup up Clion 2018.3 to. Run the ESP-IDF example and flashed to esp32 smoothly.
Re: CMake / CLion
OK, I'm still having trouble configuring the toolchain within CLion.
I can build the hello_world example using cmake from the command line, but I can't seem to configure it to build from within CLion.
In the Build,Execution,Deployment->Toolchains config (shown in the image above which I suspect won't get rendered).
What values should I be using for:
Reminder: this is on Windows.
- Environment]
- Make]
- C Compiler]
- C++ Compiler]
- Debugger]
E:\Dev\CMake\bin\cmake.exe -DCMAKE_BUILD_TYPE=Debug "-DCMAKE_C_COMPILER=E:/Dev/Espressif/ESP-IDF Tools/tools/bin/xtensa-esp32-elf-gcc.exe" "-DCMAKE_CXX_COMPILER=E:/Dev/Espressif/ESP-IDF Tools/tools/bin/xtensa-esp32-elf-c++.exe" -G "CodeBlocks - Unix Makefiles" /cygdrive/e/Source/esp32/hello_world
CMake Error: The source directory "/cygdrive/e/Source/esp32/hello_world" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
CMake Error:
Selected CMake might be incompatible with the Cygwin environment.
In order to run on Cygwin, CMake needs to be specially compiled.
Please select either CMake bundled with CLion or CMake from the Cygwin installation.
[Previous CMake output restored: 23/04/2019 2:34 PM]
Users browsing this forum: Baidu [Spider], Jimis1 and 89 guests
