Systemview with ESP32
andygg1986
Postby andygg1986 » Tue Jul 11, 2017 4:37 pm
I am trying to get Systemview up and running with my ESP32 project but I am running into some issues. I am starting with the tcp_perf example. I can get the example flashed and running without Systemview. The quick summary of the problem is that it appears to run but the output file is empty.
When I type mon esp108 apptrace start testfile, I get the following output
(gdb) mon esp108 apptrace start testfile
Start 1 app trace to testfile, size 4294967295 bytes, stop_tmo 4294967295 ms, skip 0 bytes, poll period 1 ms, wait_rst 0
stat=e00 ctrl=80
memadrstart=0 memadrend=fff traxadr=0 memsz=4000
Total trace memory: 16384 bytes
Connect targets...
esp32.cpu0: Target halted, pc=0x400D1980
esp32.cpu0: target state: halted
esp32.cpu1: Target halted, pc=0x400D1980
esp32.cpu1: target state: halted
Resume targets
Targets connected.
In another MSYS32 window, I can run make monitor which starts the cpu's. I would think this would at least give me something in the Systemview file.
I can type mon esp108 apptrace status and get
(gdb) mon esp108 apptrace status
Tracing is RUNNING. Size is 0 of 4294967295 @ 0.000000 KB/s
Data: blocks incomplete 0, lost bytes: 0
TRAX: block read time [1000000000.000000..0.000000] ms
And when I type mon esp108 apptrace stop, I get
(gdb) mon esp108 apptrace stop
Disconnect targets...
esp32.cpu1: Target halted, pc=0x400D18D3
Resume targets
Targets disconnected.
Tracing is STOPPED. Size is 0 of 4294967295 @ 0.000000 KB/s
I looked at the following places to get to the point that I am at.
http://espressif.com/sites/default/file ... p32_en.pdf
http://esp-idf.readthedocs.io/en/latest ... g-commands
https://media.readthedocs.org/pdf/esp-i ... sp-idf.pdf starting on page 420
Any help with this would be greatly appreciated.
ESP_igrr
Re: Systemview with ESP32
Postby ESP_igrr » Tue Jul 11, 2017 5:48 pm
Please follow documentation section related to SystemView:
http://esp-idf.readthedocs.io/en/latest ... nd-options
(you seem to be using 'apptrace' command instead of 'sysview')
andygg1986
Postby andygg1986 » Tue Jul 11, 2017 6:08 pm
Yes, when I tried sysview I got the following error.
(gdb) mon esp108 sysview
invalid subcommand "sysview"
in procedure 'esp108'
ESP_igrr
Postby ESP_igrr » Tue Jul 11, 2017 6:51 pm
Which likely means that the version of OpenOCD which you are using does not support SystemView yet. Which commit of OpenOCD are you using?
andygg1986
Postby andygg1986 » Tue Jul 11, 2017 7:24 pm
When I run ./src/openocd -s ./tcl -f ./esp32.cfg it says
Open On-Chip Debugger 0.10.0-dev-gebfc3bad-dirty (2017-07-07-15:48)
ESP_krzychb
Contact:
Postby ESP_krzychb » Wed Jul 12, 2017 8:08 am
The latest commit of OpenOCD with SystemView support has been merged two days ago (2017-07-10).
From the date in message above (2017-07-07) it looks like you have some older version.
andygg1986
Postby andygg1986 » Mon Jul 17, 2017 4:10 pm
I cloned the latest version of OpenOCD. When I run ./src/openocd -s ./tcl -f ./esp32.cfg it says
./esp32.cfg:47: Error: invalid command name "esp108"
In the gdb prompt, it says that monitor commands are not supported by this target.
ESP_krzychb
Contact:
Postby ESP_krzychb » Mon Jul 17, 2017 5:39 pm
With commit https://github.com/espressif/openocd-es ... 73d7388d11 (of July 10th), the command line to run OpenOCD has changed. Below is an example for ESP-WROVER-KIT with ESP-WROOM-32 module::
$ src/openocd -s tcl -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Open On-Chip Debugger 0.10.0-dev-ga39db0d (2017-07-17-19:12)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
force hard breakpoints
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
For extra details and examples please check inside of https://github.com/espressif/openocd-es ... oom-32.cfg
andygg1986
Postby andygg1986 » Mon Jul 17, 2017 8:10 pm
Thank you krzychb, that new command line got openocd running. In my window with the gdb prompt, I still get an error that esp108 is an undefined command and that monitor command is not supported by this target.
ESP_krzychb
Contact:
Postby ESP_krzychb » Tue Jul 18, 2017 4:13 pm
Hi @andygg1986,
This issue will be likely resolved by calling esp32 target instead.
Target is now selected by OpenOCD on startup basing on debugging configuration:
Dual/single …. RTOS …........ Target used
Dual ….......…. FreeRTOS …. esp32
Single …........ FreeRTOS …. esp108
Dual ….......…. none …...….. esp108
Single …........ none ….....… esp108
In short I see the same on MSYS2 :(
Need to do some troubleshooting and will post again.
Users browsing this forum: No registered users and 188 guests
