Hi all
I am looking for a way to configure the BLE radio transmit output power to class 3 (range < 1m) for advertising packets.
According to the datasheet this should be possible.
I could not find any API to do this.
Anybody knows how to do this?
I already tried changing BTM_BLE_ADV_TX_POWER in bt_target.h but this had no effect.
Any help is greatly appreciated.
Dura
How to configure BLE transmit output power classes
Re: How to configure BLE transmit output power classes
This works now with the latest version from master.
There are new functions in bt.h:
* @brief Set BLE TX power
* Connection Tx power should only be set after connection created.
* @param power_type : The type of which tx power, could set Advertising/Connection/Default and etc
* @param power_level: Power level(index) corresponding to absolute value(dbm)
* @return ESP_OK - success, other - failed
esp_err_t esp_ble_tx_power_set(esp_ble_power_type_t power_type, esp_power_level_t power_level)
why esp32 wroverchip limit bluetooth range around 2 meters?
hii all
i am now dealing with esp32 gatt client program. in that my esp32 could not connecting to the gatt server(even it not found in scanning). then i flashed the ibeacon program in the examples to the esp32. later i scanned it from my phone, in range of 1.5 meter it showing in phone scanner. but if i exceed the range beyond 1.5 meter it not getting in my phone scanner. i am new to this esp32 world. will you please help me?. whether i should change anything in make menuconfig?.
some one please help me...
Re: why esp32 wroverchip limit bluetooth range around 2 meters?
Hi, try to set tx value to 20 in SDK config -> Component config -> PHY config.anandvilayil wrote:hii all
Users browsing this forum: Majestic-12 [Bot] and 119 guests
