data encryption
Trialblazer47
data encryption
Postby Trialblazer47 » Wed Nov 01, 2017 12:55 pm
I wanted to encrypt data to be sent over ble. I am trying to reuse the security file provided with blufi example.
I think the two API blufi_aes_encrypt & blufi_aes_decrypt are to be used to encrypt and decrypt. I tried to make a test code.
first I initalized
void app_main()
  char *input="hello";
  char *out;
  if( security_init() == ESP_FAIL  )
      ESP_LOGI(TAG,"Security init failed.\n");
ESP_LOGI(TAG,"Security done.\n");
aes_encrypt(10, input,5);                       <---- but this keeps crashing  I don't understand its input.
ESP_LOGI(TAG,"Encrypted : %s \n",input);
I am also thinking where the encryption key set?
I want simple way to encrypt and decrypt data. so please any example would be helpful.
Thanks.
blekyo
Re: data encryption
Postby blekyo » Mon Nov 27, 2017 9:14 am
I'm getting the same issue you. Did you you find out how to make it work?
Trialblazer47
Re: data encryption
Postby Trialblazer47 » Tue Dec 05, 2017 1:32 pm
no than I gave up that idea.
Thanks.
chegewara
Re: data encryption
Postby chegewara » Tue Dec 12, 2017 9:41 pm
I dont know why this is not answered yet, since its a simple answer. This is wrong usage:
Check this https://github.com/espressif/esp-idf/bl ... /aes.h#L21
and this https://github.com/espressif/esp-idf/bl ... .h#L49-L52
and you will have answers why it crash and where to set encryption key.
blekyo
Re: data encryption
Postby blekyo » Fri Dec 15, 2017 3:27 am
OK thanks, after a time spent looking on the code, I managed to understand how to use the mbedtls aes encryption/decryption
Users browsing this forum: Bing [Bot] and 105 guests
